It's in the engine bay, just in front of the LH shock tower. Might be on the other side for LHD market but I don't think so.
Those wires are on connector B as shown in the wiring diagram. That is shown as E77 here. Again, LHD may be different, doesn't look like it for these wires from the diagram though.
Symbols
(Terminal No.)
Wiring Color
Terminal Description
Condition
Standard Voltage
OPST (A55-2) - E1 (A55-18)
BR - W-B
Oil pump motor
Power switch on (IG) to on (READY)
Pulse generation
(Waveform 1)
OPM1 (A55-3) - E1 (A55-18)
B - W-B
Oil pump motor
Power switch on (READY)
Pulse generation
(Waveform 2)
SMRP (A55-17) - E1 (A55-18)
V - W-B
System main relay
Pulse generation
(Waveform 3)
BATT (A55-20) - E1 (A55-18)
L - W-B
Constant power source
Always
10 to 14
MREL (A55-21) - E1 (A55-18)
G - W-B
Main relay
10 to 14
ST2 (A55-22) - E1 (A55-18)
Y-B - W-B
Starter signal
0 to 1.5
IMI (A55-24) - E1 (A55-18)
LG - W-B
Immobilizer communication
Immobilizer communicating
Pulse generation
(Waveform 4)
IMO (A55-25) - E1 (A55-18)
W-R -W-B
Pulse generation
(Waveform 4)
ILKI (A55-40) - E1 (A55-18)
W-B - W-B
Interlock switch
Power switch on (IG), inverter cover and service plug grip installed correctly
0 to 1.5
W-B - W-B
Interlock switch
Power switch on (IG), inverter cover and service plug grip detached
10 to14
SMRB (A55-41) - E1 (A55-18)
W - W-B
System main relay
Power switch off to on (READY)
Pulse generation
(Waveform 3)
CANL (A55-42) - E1 (A55-18)
B - W-B
CAN communication system
Pulse generation
(Waveform 5)
CANH (A55-43) - E1 (A55-18)
W - W-B
Pulse generation
(Waveform 5)
CAN- (A55-44) - E1 (A55-18)
B -W-B
Pulse generation
(Waveform 6)
CAN+ (A55-45) - E1 (A55-18)
W -W-B
Pulse generation
(Waveform 6)
+B (A55-46) - E1 (A55-18)
B-R - W-B
Power source
10 to14
SFTD (A55-47) - E1 (A55-18)
V - W-B
Transmission Control Switch
Power switch on (IG), shift lever in S position
10 to14
V - W-B
Power switch on (IG), shift lever in negative (-) side
0 to 1.5
SFTU (A55-48) - E1 (A55-18)
Y-R - W-B
10 to14
Y-R - W-B
Power switch on (IG), shift lever in positive (+) side
0 to 1.5
M (A55-49) - E1 (A55-18)
W-G - W-B
10 to14
W-G - W-B
Power switch on (IG), shift lever in except S position
0 to 1.5
GI (A55-52) - E1 (A55-18)
W - W-B
Camshaft position signal
Power switch on (READY), engine started
Pulse generation
(Waveform 7)
NEI (A55-53) - E1 (A55-18)
B - W-B
Crankshaft position signal
Pulse generation
(Waveform 8)
SPDI (A55-54) - E1 (A55-18)
V - W-B
Vehicle speed signal
Approximately 20 km/h (12 mph)
Pulse generation
(Waveform 9)
NODD (A55-55) - E1 (A55-18)
GR - W-B
DC/DC operation
Converter operating normally
5 to 7
GR - W-B
DC/DC operation
Converter not operating normally
2 to 4
GR - W-B
DC/DC operation
0.1 to 0.5
VLO (A55-56) - E1 (A55-18)
L - W-B
DC/DC operation monitor / voltage change signal
Pulse generation
(Waveform 10)
SIO (A55-57) - E1 (A55-18)
Y - W-B
HV battery blower fan
Power switch on (IG), during active test
Pulse generation
(Waveform 11)
OPM2 (A55-58) - E1 (A55-18)
L-B - W-B
Oil pump motor
10 to 14
IWP (A55-61) - E1 (A55-18)
Y - W-B
HV water pump signal
Pulse generation
(Waveform 12)
TC (A55-63) - E1 (A55-18)
G-Y - W-B
Diagnosis terminal
10 to 14
VCP2 (A55-64) - E1 (A55-18)
B - W-B
Accelerator pedal position sensor power source (for VPA2)
4.5 to 5.5
VCP1 (A55-65) - E1 (A55-18)
G - W-B
Accelerator pedal position sensor power source (for VPA1)
4.5 to 5.5
ST1- (A55-70) - E1 (A55-18)
G-W - W-B
Brake cancel switch
Power switch on (IG), brake pedal depressed
0 to 1.5
G-W - W-B
Brake cancel switch
Power switch on (IG), brake pedal released
10 to 14
HSDN (A55-73) - E1 (A55-18)
B - W-B
MG shutdown signal
0 to 1.5
PMET (A55-78) - E1 (A55-18)
L - W-B
Power meter signal
Pulse generation
(Waveform 13)
SMRG (A55-81) - E1 (A55-18)
L - W-B
System main relay
Pulse generation
(Waveform 3)
HTM- (A55-82) - E1 (A55-18)
W - W-B
Communication system HV to MG
Pulse generation
(Waveform 14)
MTH- (A55-83) - E1 (A55-18)
W - W-B
Communication from MG to HV
Pulse generation
(Waveform 15)
CLK- (A55-84) - E1 (A55-18)
W - W-B
MG communication clock signal
Pulse generation
(Waveform 16)
REQ- (A55-85) - E1 (A55-18)
W - W-B
MG communication request signal
Pulse generation
(Waveform 17)
IGSW (A55-86) - E1 (A55-18)
B-W - W-B
IG signal
10 to 14
BTH+ (A55-91) - E1 (A55-18)
B - W-B
Communication from battery to HV
Pulse generation
(Waveform 18)
ABFS (A55-96) - E1 (A55-18)
B - W-B
Airbag activation signal
Power switch on (READY) (2 seconds after ACC ON)
Pulse generation
(Waveform 19)
HTM+ (A55-105) - E1 (A55-18)
B - W-B
Pulse generation
(Waveform 14)
MTH+ (A55-106) - E1 (A55-18)
B - W-B
Communication system MG to HV
Pulse generation
(Waveform 15)
CLK+ (A55-107) - E1 (A55-18)
B - W-B
Pulse generation
(Waveform 16)
REQ+ (A55-108) - E1 (A55-18)
B - W-B
Pulse generation
(Waveform 17)
WP (A55-109) - E1 (A55-18)
G-Y - W-B
A/C WP relay signal
Below 2
VPA2 (A55-110) - E1 (A55-18)
R - W-B
Accelerator pedal position sensor (for accelerator pedal position detection)
Power switch on (IG), accelerator pedal released
1.0 to 2.2
R - W-B
Power switch on (IG), engine stopped, shift lever in P position, accelerator pedal fully depressed
3.4 to 5.3
VPA (A55-111) - E1 (A55-18)
L - W-B
0.4 to 1.4
L - W-B
2.6 to 4.5
STP (A55-112) - E1 (A55-18)
R-B - W-B
Stop light switch
Brake pedal depressed
10 to 14
R-B - W-B
Stop light switch
Brake pedal released
0 to 1.5
BTH- (A55-114) - E1 (A55-18)
W - W-B
Pulse generation
(Waveform 18)
THB (A55-115) - E2 (E77-54)
L - W-B
Auxiliary battery temperature sensor signal
Auxiliary battery temperature 25°C (77°F)
1.8 to 2.5
L - W-B
Auxiliary battery temperature 60°C (140°F)
0.7 to 1.3
RDY (A55-117) - E1 (A55-18)
W-L - W-B
READY state
Pulse generation
(Waveform 20)
SP (E77-1) - E1 (A55-18)
G - W-B
SP solenoid valve signal
During active test
10 to 14
SL1- (E77-2) - SL1+ (E77-3)
L - Y
SL1 solenoid valve signal
During active test
Pulse generation
(Waveform 21)
+BS (E77-4) - E1 (A55-18)
W - W-B
Park / Neutral position switch power source
10 to 14
PB3 (E77-5) - E1 (A55-18)
G - W-B
Pressure switch 3
10 to 14
PB2 (E77-6) - E1 (A55-18)
G-W - W-B
Pressure switch 2
10 to 14
PB1 (E77-7) - E1 (A55-18)
G-R - W-B
Pressure switch 1
10 to 14
STB (E77-8) - E1 (A55-18)
B - W-B
A/C communication signal
Power switch on (READY), air conditioning system stop
Pulse generation
(Waveform 22)
CLK (E77-9) - E1 (A55-18)
G - W-B
Pulse generation
(Waveform 22)
ITE (E77-10) - E1 (A55-18)
W - W-B
Pulse generation
(Waveform 22)
ETI (E77-11) - E1 (A55-18)
Y - W-B
Pulse generation
(Waveform 22)
MJ (E77-12) - E1 (A55-18)
B - W-B
Park / Neutral position switch signal
Power switch on (IG), shift lever in P, R, N or D position
10 to 14
FD (E77-13) - E1 (A55-18)
L-Y - W-B
Power switch on (IG), shift lever in D position
10 to 14
L-Y - W-B
Power switch on (IG), shift lever in except D position
0 to 1.5
RV (E77-14) - E1 (A55-18)
G-Y - W-B
Power switch on (IG), shift lever in R position
10 to 14
G-Y - W-B
Power switch on (IG), shift lever in except R position
0 to 1.5
D (E77-16) - E1 (A55-18)
Y - W-B
10 to 14
Y - W-B
0 to 1.5
N (E77-17) - E1 (A55-18)
R - W-B
Power switch on (IG), shift lever in N position
10 to 14
R - W-B
Power switch on (IG), shift lever in except N position
1.5 to 3.0
R (E77-18) - E1 (A55-18)
L - W-B
10 to 14
L - W-B
0 to 1.5
P (E77-19) - E1 (A55-18)
G - W-B
Power switch on (IG), shift lever in P position
10 to 14
G - W-B
Power switch on (IG), shift lever in except P position
0 to 1.5
SL2- (E77-21) - SL2+ (E77-22)
W - L-W
SL2 solenoid valve signal
During active test
Pulse generation
(Waveform 23)
FCTL (E77-41) - E1 (E54-18)
BR - W-B
Cooling fan relay
10 to 14
SP2- (E77-48) - SP2+ (E77-49)
Y - L
Transmission revolution sensor signal
Driving at approximately 55 km/h (34 mph) with power switch on (READY)
Pulse generation
(Waveform 24)
TOPM (E77-53) -E2 (E77-54)
R - W-B
Oil pump motor temperature sensor
Power switch on (IG), ambient temperature 25°C (77°F)
2.4 to 3.1
THO (E77-55) - E2 (E77-54)
G-Y - W-B
Transmission fluid temperature sensor
2.2 to 2.8
MMT (E77-57) - MMTG (E77-58)
G - GR
Motor temperature sensor
1.9 to 2.8
G - GR
Power switch on (IG), ambient temperature 60°C (140°F)
1.1 to 1.8
GMT (E77-59) - GMTG (E77-60)
L - R
Generator temperature sensor
1.9 to 2.8
L - R
1.1 to 1.8
Sorry, the table didn't come out very well. I've attached it as a CSV as well which you can import in to a spreadsheet program, or read "well enough" in notepad.
The bit you care about is:
G - W-B
Pressure switch 3
10 to 14
G-W - W-B
Pressure switch 2
10 to 14
G-R - W-B
Pressure switch 1
10 to 14
