SOC Meter Aliexpress ...just a Toy ???
zippy500
Has thanked: 100 times
Been thanked: 7 times
Post by zippy500 »
Was looking at these on aliexpress
https://www.aliexpress.com/i/1005006340553775.html
What do you think as just a temporary solution .
Has a current sensor to read current , Am just more interested it as a volt meter
Has thanked: 330 times
Been thanked: 848 times
Re: SOC Meter Aliexpress ...just a Toy ???
Aliexpress items + HV, not recommended
Been thanked: 413 times
tom91 wrote: Tue Apr 15, 2025 3:04 pm Aliexpress items + HV, not recommended
My friend has one in his Mazda RX8 connected at about 300Vdc. He says it is legit for 2 years now.
I have one here prepared for installation. It is a 500A 500V version. I will install main unit and sensor inside plastic contact box just to see if it works with 380Vdc. Of course everything will be fused by glass fuses.
LCD i will install inside cabin, again to see if wifi signal can push through the firewall. Will post results here then.
jadamcak
Post by jadamcak »
Hi, I wanted to use this one
https://www.aliexpress.com/item/1005003942185757.html
But at 180V it overheats under 1 minute. After cooldown it works again.
I was using it at 48V without problem.
Jan, Trying to use yaris electronics with V1d and MGR version 4NM with LiFePO4 56s pack for small tractor.
