Setting max current over CAN [SOLVED]
- ElMaco
- Has thanked: 11 times
I can't find documentation anywhere of how to set max current (in the inverter) to a value received via CAN (i.e. from the BMS). Is this not possible?
I would like the BMS to be in charge of how much current the inverter/motor is allowed to pull. My idea was to have the max output current, calculated by the BMS, presented on CAN and used by the inverter.
Any ideas?
I have a Leaf motor, EM-57, with a gen 3 gen 2 OI board. [edited for correctness]
Any ideas?
50 ft slow boat with Nissan LEAF EM-57, OI gen 2. FW 5.35. Dual (2P) KIA Eniro 64kWh (98S), Orion BMS2.
- Has thanked: 455 times
- Been thanked: 1771 times
Re: Setting max current over CAN
Wait, you're successfully running a Gen3 OI board? I.e. in Leaf Gen3 inverter.
Apart from that, if you use the new "green" web interface you can map idcmax (accel) and idcmin (regen) just like any other item.
- jerrykco
- Has thanked: 223 times
- Been thanked: 38 times
Hi johu, is there sarcasm in this part of your response ? What am I missing?
Jerry Kauffman
jerryk48 at gmail dot com
- Has thanked: 266 times
- Been thanked: 186 times
Gen 3 leaf board is a work in progress. We haven't gotten it to run yet. If you have a gen 3 leaf board working we would love to hear about it. There's a link in my signature at the bottom of this post.
If you mean a revision 3 or something else it would be good to clarify what you have.
- ElMaco
Sorry about my misleading information. Blaming fat fingers. I have a Gen 2 OI board. I am correcting the initial post to avoid further confusion.
Great that there is an available solution to my issue. I will upgrade to the latest "green" interface and take it from there. Thanks Johu!
- ElMaco
Been looking around the open inverter site for the latest files to update the web UI, but I can't find them. I am expecting index.* files, but can't find any.
Can someone please help me pointing out where I find the files I need to upload with the upload interface in the the web UI?
CAN or serial attached?
CAN: https://github.com/jsphuebner/esp32-web ... ckend/data
Serial: https://github.com/jsphuebner/esp32-web ... ckend/data
- ElMaco
Well, I have been running FW 5.35, monitoring and editing over WiFi. My idea was to use the upload via WiFi to update the WebUI. I am afraid I don't understand the options "CAN or serial attached".
Can or serial is just the means of communication between the web interface and your board. For instance if you are using the external canbus datalogger you'd use the can version.
- ElMaco
Great!
So, having determined that my wifi-setup is on a serial dongle, I just upload the files found on https://github.com/jsphuebner/esp32-web ... ckend/data with the upload feature in the web interface, right?
Don't want to mess up and cut comm to the inverter.
- ElMaco
Re: Setting max current over CAN [SOLVED]
I need to upload the files for the
1. Do I upload all the files in the repository https://github.com/jsphuebner/esp32-web ... ckend/data, or only some of them?
2. There seems to be a script file "upload.sh" in the repository. What is the syntax for using it?
Please advice!
[Edit] finding Johu's reply to another thread, q1 is answered, I upload all files.
Answers to both questions confirmed!
Can also confirm the solution to the initial question in this thread, mapping idcmax over CAN, with the new green web-UI.
Thanks to everyone contributing to widening my understanding.
through WiFi on serial, using the web interface. I have a few questions on how to do this.
Please advice!
For q2, browsing through the shell script I assume the syntax for the upload script (https://github.com/jsphuebner/esp32-web ... /upload.sh) is "./upload.sh 192.168.4.1 file_or_folder". If "file_or_folder" is omitted, the script assumes "./data/*".johu wrote: ↑Wed May 14, 2025 8:19 am If you only want to update the UI you can just upload all files in "/data" one-by-one with the button that usually updates the inverter. Alternatively you can use curl as featured by Scrappy. No real need to use any of the OTA/UART paths.
Some versions tell you "Only .bin file" but you can ignore that.
