Leaf 62kWh module power path
- ianlighting
- Has thanked: 152 times
- Been thanked: 59 times
In particular, at which point the service disconnect comes?
My guess is that there’s a left / right split. So from the diagram,
26 - 33 (right)
25 - 21, 35,34 (left)
Is the disconnect between 33 and 34? Or maybe 33 and 25?
I’m considering buying one, but I’ve had no luck with previous tear downs that cover this. I’m trying to work out whether the different modules can work as they are built by Nissan.
Thanks.
Re: Leaf 62kWh module power path
I remember 33 and 34, btw I'll check for it in the documentation if any
- ianlighting
