Unstable rms current reading and a possible fix  [SOLVED]
nailgg
Post by nailgg »
Hi everyone, it's my first post in this forum.
So everytime I look at the il1rms and il2rms values with a constant load and speed on my motor, the RMS current calculated by the software varies. For example, when I am spinning the motor with fmax = 50 with constant full throttle with no motor load, the clamp meter I put on one of the motor phases reads almost constant ~30Arms while the software reading gives constantly changing 20-40Arms. Then I decided to try reading a current from the wall socket, so I unplugged the DC bus cable from the inverter, wound a cable coming from the wall 10 times through my current sensor. Then I started the inverter operation, and I put some load (heater) on the wound cable. I noticed that the rms current readings were perfectly nice (10x the clamp meter), but only until I push the throttle. So it's possibly because of the gate drivers pulling too much current from the 5V line, causing some voltage drop on the current sensors, resulting in a small negative offset in the current.
Johannes' software calculates the rms current by finding the max/min current values through half a current period (say 50 hz), then an abs(1/sqrt(2)) operation is done. If we assume that the motor RMS current does not change within a period, we can change it to finding both the negative/positive rms values and averaging these two. Modified the code, and I got perfect rms reading on both the current through the wall and to the motor.
I'm not sure if anyone else was having this issue too, but if there is, the following code change (pwmgeneration.cpp) fixes the issue.
static bool CalcRms(s32fp il, s32fp illast, s32fp& max, s32fp& rms, int& samples, s32fp prevRms)
   const s32fp oneOverSqrt2 = FP_FROMFLT(0.707106781187);
   bool signChanged = ((illast <= 0 && il > 0) || (illast > 0 && il <= 0)) && samples > 10;
   if (signChanged)
      //rms = FP_MUL(oneOverSqrt2, max); // original rms calculation
      rms = FP_DIV((FP_MUL(oneOverSqrt2, max) + prevRms), FP_FROMFLT(2)); // average with previous rms reading
      max = 0;
      samples = 0;
   il = ABS(il);
   max = MAX(il, max);
   samples++;
   return signChanged;
static s32fp ProcessCurrents()
   static s32fp currentMax[2];
   static int samples[2] = { 0 };
   s32fp il1 = GetCurrent(AnaIn::il1, ilofs[0], Param::Get(Param::il1gain));
   s32fp il2 = GetCurrent(AnaIn::il2, ilofs[1], Param::Get(Param::il2gain));
   s32fp rms;
   s32fp il1PrevRms = Param::Get(Param::il1rms);
   s32fp il2PrevRms = Param::Get(Param::il2rms);
   if (CalcRms(il1, Param::Get(Param::il1), currentMax[0], rms, samples[0], il1PrevRms))
      Param::SetFlt(Param::il1rms, rms);
      if (opmode != MOD_BOOST || opmode != MOD_BUCK)
         //rough approximation as we do not take power factor into account
         s32fp idc = (SineCore::GetAmp() * rms) / SineCore::MAXAMP;
         idc = FP_DIV(idc, FP_FROMFLT(1.2247)); //divide by sqrt(3)/sqrt(2)
         idc *= fslip < 0 ? -1 : 1;
         Param::SetFlt(Param::idc, idc);
   if (CalcRms(il2, Param::Get(Param::il2), currentMax[1], rms, samples[1], il2PrevRms))
      Param::SetFlt(Param::il2rms, rms);
   Param::SetFlt(Param::il1, il1);
   Param::SetFlt(Param::il2, il2);
   return GetIlMax(il1, il2);
Re: Unstable rms current reading and a possible fix
Thanks Nail, will add it to the next version or you make a pull request.
nailgg
Post by nailgg »
Sure. Just made the pull request :)
nailgg
Post by nailgg »
Johannes, I was wondering if changing the ADC sampling rate from 7.5 cycles to 28.5 cycles would affect the timings of the main loop? With 28.5 cycles the ADC readings were much better than 7.5, but I couldn't make sure whether it would cause more cpu load. It probably won't affect anything because ADC conversions are done in the DMA module, but I might be missing some point. :)
I'm referring to this line in anain_prj.h:
//#define SAMPLE_TIME ADC_SMPR_SMP_7DOT5CYC
#define SAMPLE_TIME ADC_SMPR_SMP_28DOT5CYC
Like you observed CPU load will not change at all since it's all done in hardware. What you're changing is not the sampling rate but the number of clock cycles that the sample&hold capacitor is connected to the input pin. So erm yes actually you are changing the sampling rate but it gets lower.
Maybe over current detection will react differently but all other signals are so slow that it won't matter/change for the better.
nailgg
Post by nailgg »
johu wrote: Fri Apr 05, 2019 4:22 pm So erm yes actually you are changing the sampling rate but it gets lower.
Exactly. So it wouldn't have a significant impact on the slow ADCs such as throttle pot and similar stuff, but current readings are affected. With zero current on the motor and with my 800A dual range current sensors my il1/il2 values still read a bit noisy, and by increasing the S+H window they got much more stabilized.
johu wrote: Fri Apr 05, 2019 4:22 pm Maybe over current detection will react differently
I guess you meant the current limiting function would react differently but not the overcurrent detection, as the OC detection circuitry is based on the comparator hardware :)
Thanks so much, I will report back if I observe any negative impact.
doobedoobedo
Post by doobedoobedo »
Quick question regarding this to get a better understanding. Are the ADC current readings synced with the PWM pulses? Or does it not matter because of the inductance in the motor?
nailgg
Post by nailgg »
doobedoobedo wrote: Sat Apr 06, 2019 9:37 am Quick question regarding this to get a better understanding. Are the ADC current readings synced with the PWM pulses? Or does it not matter because of the inductance in the motor?
Nop, they are not synced with the PWM pulses on Johannes' software, and it also doesn't matter because of the motor inductance, like you said. ADC continuous conversion is done with the APB2 clock which is 72MHz, with a prescaler of 6 so 12MHz.
