Interactive EV learning circuit board! All the core concepts explained on one circuit board!
janosch
Has thanked: 73 times
Been thanked: 60 times
Post by janosch »
Hello,
I made a board that helps you understand all the important concepts of a modern electric car - on a single board.
You might be overwhelmed by all the things that there are to learn, just as I was when I started out. Hopefully this can help you.
See the video for details:
You can pre-order the EV Mastermind Kit if you want, reply here, or email me at hello@foxev.io
There will be a trial limited to ten early adopters.
