1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck  [FINISHED]
Has thanked: 330 times
Been thanked: 452 times
Re: 1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck
DIY EV Conversions What I'm Up To
Has thanked: 291 times
Been thanked: 177 times
Post by MattsAwesomeStuff »
I like how you label your bins directly. Not on a label, no, right onto the bin. Because you're a realist. You know that the bin will never be repurposed. That would imply that the purpose of a bin that holds things, is for the things in the bin to eventually be removed from the bin and used. No no, there's confidence in this hording. This is the bin that holds wires. It will never not hold wires.
The bin is less of a container to temporarily hold something, and more of a sarcophagus to entomb it for maybe thousands of years.
MattsAwesomeStuff wrote: Thu Jan 04, 2024 2:18 am
Should've grabbed a Prius pedal while you were picking and/or pulling.
This is one of those items that is perplexingly hard because of how easy it is. People will say stuff like "Oh, plenty of vehicles use digital pedals these days, any will work." Well I can't go to a store and buy an "any'. I can't go to a junkyard and remove it from an "any". It's common enough people don't want to list what makes/models because it feels wasteful, but not common enough that someone who didn't know exactly what to look for wouldn't waste most of their time and be frustrated.
I feel like it would be better to say "Dozens of vehicles use these. Here's 6 of the most common vehicles sold that are already 10-15 years old in junkyards to take them from, each is a little different depending on what you'd like, all will work." That's something someone can ask for, shop for, or look for themselves.
The only reason I have a Prius pedal is because it was literally the only vehicle anyone listed by name that had a suitable pedal. Maybe it's the worst of the options available, maybe it's the best. I don't know.
Challenge Accepted!
Has thanked: 99 times
Been thanked: 75 times
Post by jrbe »
One for each motor?
Has thanked: 253 times
Been thanked: 65 times
Post by Jacobsmess »
jrbe wrote: Fri Jan 12, 2024 11:24 pm One for each motor?
One for each wheel and motor. True 4 wheel drive..
Your wish is my command.
not sure about this appendage
Electruck Doing Truck Things:
Dusty the Good Samaritan, delivering a FREE chair from a Garage Sale for a complete stranger in order to surprise her husband.
Tachopis
Been thanked: 6 times
Post by Tachopis »
Hey Gregski, I'd like to ask you a question that I haven't found by diving into your posts and videos. You started by installing the Tesla PCS charger with DCDC; are you still using it? Because I think you've been trying other solutions, right? I would like to install it in the Jag I'm converting, with Damien's controller, but I can't find many examples where everything (Charger and DCDC) worked without issues. If you're not using it, could you tell me why? Thanks dude, soooo cool truck you have ;) a loooot of work I know.
Tachopis wrote: Thu Feb 29, 2024 8:07 pm Hey Gregski, I'd like to ask you a question that I haven't found by diving into your posts and videos. You started by installing the Tesla PCS charger with DCDC; are you still using it? Because I think you've been trying other solutions, right? I would like to install it in the Jag I'm converting, with Damien's controller, but I can't find many examples where everything (Charger and DCDC) worked without issues. If you're not using it, could you tell me why? Thanks dude, soooo cool truck you have ;) a loooot of work I know.
PMed you
Gregski wrote: Fri Jan 12, 2024 8:12 pmChallenge Accepted! IMG_0923.JPG
Btw, what was pedal #2? I hacked my straight Prius pedal into almost exactly that shape because I didn't know there was something like that out there.
MattsAwesomeStuff wrote: Fri Mar 01, 2024 2:15 am Btw, what was pedal #2? I hacked my straight Prius pedal into almost exactly that shape because I didn't know there was something like that out there.
Doing things the hard way, you would think you are auditioning for Good Enuff Garage? don't walk by any unmarked white vans with no windows, we might just abduct you, we are always on the lookout for a Lead Fabricator
2010 Honda Fit
celeron55
Has thanked: 28 times
Been thanked: 110 times
Post by celeron55 »
Gregski wrote: Fri Mar 01, 2024 3:32 am Doing things the hard way, you would think you are auditioning for Good Enuff Garage? don't walk by any unmarked white vans with no windows, we might just abduct you, we are always on the lookout for a Lead Fabricator
As the Lead Fabricator, we are expecting from you the complete confidence to fabricate no matter the time, the cost, or the fact that every day we are surronded by parts exactly like the one you are about to fabricate.
Gregski wrote: Fri Mar 01, 2024 3:32 amwe are always on the lookout for a Lead Fabricator
You're aware that I "machined" a coupler by spinning it up full speed on the motor, and then easing a 7" circular saw blade into it yes?
Somewhere, deep down inside, you have standards. They're there, I know they are.
And mine are lower.
MattsAwesomeStuff wrote: Fri Mar 01, 2024 9:04 pm You're aware that I "machined" a coupler by spinning it up full speed on the motor, and then easing a 7" circular saw blade into it yes?
And mine are lower.
What do you think happened to the last "lead fabricator"? it's a job that requires a particular willingness...
Jacobsmess wrote: Fri Mar 01, 2024 10:26 pm What do you think happened to the last "lead fabricator"? it's a job that requires a particular willingness...
went the same way as all the Spinal Tap drummers
Well it looks like I will no longer have to drive the whopping 7.4 miles to Costco, since they just opened up a brand new one only 4.5 miles away from our house, I better update this table!
Oh, and this one is getting EV chargers, awesome !
Gregski wrote: Mon Aug 28, 2023 2:06 pm
DISTANCE DESTINATION DESCRIPTION
15.0 Best Mates Domicile and this is mostly freeway driving
13.0 Mamas House go over there to replace the batteries in her TV remote
8.3 KAISER doctor
7.4 Costco cheap pizza aint gonna eat itself
7.0 Airport flights
4.1 Golden1 Credit Union like a bank but staffed by actual humans
3.8 O'Reilly truck parts
3.5 Home Depot maintenance and repairs
2.8 Target toilet paper & paper towels source
2.7 Optometrist one visit per year
2.7 Olive Garden (Restaurant) Zuppa Toscana
2.6 Dentist two visits per year
2.4 UPS AMAZON returns mostly
2.3 Taqueria (Restaurant) Taco Tuesdays
2.1 NAPA truck parts
1.8 Raley's grocery store
1.8 AutoZone truck parts
1.8 KOHL's AMAZON returns mostly
1.7 Chang's (Restaurant) Chinese food
1.7 Post Office shipping & stamps
1.6 Jack's Urban Eats (Restaurant) one of few restaurants all family members like
1.4 Track 7 Brewery BEER & Food Trucks
0.7 CVS toilet paper & paper towels source, if I don't feel like driving all the way to Target
0.6 ACE Hardware maintenance and repairs, if I don't feel like driving all the way to Home Depot
sure glad they put up this sign
Alibro
Has thanked: 271 times
Been thanked: 150 times
Post by Alibro »
I can't believe you made a spreadsheet of your local journeys. :lol:
I need a bigger hammer!
Alibro wrote: Mon Mar 18, 2024 9:09 pm I can't believe you made a spreadsheet of your local journeys. :lol:
a Table, not a spreadsheet, lol
P.S.Mangelsdorf
Has thanked: 96 times
Been thanked: 96 times
Post by P.S.Mangelsdorf »
Gregski wrote: Mon Mar 18, 2024 4:01 pm a brand new one only 4.5 miles away from our house, I better update this table!
They just built one about the same distance from my house, and despite 5-10 paved acres, didn't put in any charging infrastructure. And its on a route that needs more anyways!
P.S.Mangelsdorf wrote: Tue Mar 19, 2024 2:30 pm They just built one about the same distance from my house, and despite 5-10 paved acres, didn't put in any charging infrastructure. And its on a route that needs more anyways!
well that sucks, ours did not get a gas station so everyone is bent about that, but it shares a parking lot with Chevron
P.S.Mangelsdorf
Gregski wrote: Tue Mar 19, 2024 2:37 pm ours did not get a gas station so everyone is bent about that, but it shares a parking lot with Chevron
Yeah ours got a gas station despite being the lot next to a gas station that has plenty of pumps. In fact, we got the suburbia trifecta: Costco, Chick-Fil-A, and Starbucks all on one lot/development, but of course spread all over the place.
