Gen 3 dual board small udc not reading
BigDaddyWeldz
Has thanked: 4 times
Post by BigDaddyWeldz »
I have played with gain and offset. I have -5v. I have triple checked the 50 pin under the microscope. When I connect 80V to the invertor there is no change in udc. Inverter does work and spin the motor during testing. I fear there is some thing wrong with the inverter.
Brian AKA Daddy ;)
BigDaddyWeldz
Re: Gen 3 dual board small udc not reading
Update I am losing -5 after installing board.
Brian AKA Daddy ;)
Has thanked: 302 times
Been thanked: 186 times
Post by MattsAwesomeStuff »
When in doubt, when you want people to help you troubleshoot, info dump.
Take clear pictures of your setup.
Show your settings.
BigDaddyWeldz
I think some thing is going on with ic17 with the 2276. It doesn't start when every thing is pugged in but works when everything is unplugged. I have hvil bridged but I don't believe its used anyway? I built the wrong board for my inverter so it is missing 2 screws and a ground screw near the ic17.
Brian AKA Daddy ;)
Again, look at the amount of info you've shared, and put yourself in the shoes of someone troubleshooting for you. Could you have troubleshot a similar task with that small of information?
I don't know how to solve your problem, but I can only imagine that the people able to do this, their first question is going to be that you provide them more info.
BigDaddyWeldz
Brian AKA Daddy ;)
BigDaddyWeldz
Should I have -5v with every thing hooked up?
Brian AKA Daddy ;)
uhi22
Has thanked: 93 times
Been thanked: 428 times
Post by uhi22 »
Looks like you have wrong udcgain and udcoffset. I propose to start with its default values. And be more verbose on your test conditions. Eg we see 664V udc, but have no information about the physical voltage.
BigDaddyWeldz
Sorry 0v connected. I will recalibrate and report back.
Brian AKA Daddy ;)
BigDaddyWeldz
Brian AKA Daddy ;)
BigDaddyWeldz
udcgain 5 and udcofs 0 Default from wiki I get udc resting at 133v with 0v or 80v connected to the hv no change on plot during precharge. Is 80v too low?
Brian AKA Daddy ;)
uhi22
Post by uhi22 »
Looks like a hardware issue in the measuring circuit. Maybe a broken connection on the ADC pin or a shortcut to an other signal. I'd expect that 0V HV is shown as nearly 0, and 80V is shown as nearly 80V. Maybe with some tolerances of +/5V.
BigDaddyWeldz
I had a lot of problems with my PCB from jlc. I had a failed capacitor and resistor on 26v line so far so I’m not surprised. I will look through the schematics again thanks for the input.
Brian AKA Daddy ;)
Has thanked: 75 times
Been thanked: 306 times
Most likely culprit is the 50 pin connector, I'd check it a fourth time, the specific pin. It was a dry joint on my single board with UDC not working
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
BigDaddyWeldz
Will do.Thank you everyone for your help. The lm2776 let the smoke out during yesterday’s test. I’m waiting on a replacement. I’m going through the caps and I will check the 50 pin one more time. I’m just glad the inverter outputs pwm.
Brian AKA Daddy ;)
uhi22
Post by uhi22 »
If the lm2776 smoked, there is more wrong. You should check its input voltage, and how much current is on the negative rail which the lm2776 should produce. Can be done with a lab power supply.
BigDaddyWeldz
could not find my nice power supply. So I improvised with one of my chargers. I'm happy to report the udc reads correctly when supplying the -5v from the power supply. Current was set to .050 ma. Thinking it was a defective 2776. Thank you uhi22 ! Great idea with the power supply.
Brian AKA Daddy ;)
