[DRIVING] BMW Z3
andybpowell
Has thanked: 197 times
Been thanked: 234 times
Re: [WIP] BMW Z3
Post by andybpowell »
tom91 wrote: Wed Feb 28, 2024 12:19 pm So currently you are hitting +/- 110-120A consistently, has your voltage been dropping and you not charged when doing tests over the past week?
It is very likely that you are hitting a discharge power limit.
no batt volts doesn't drop much and I've set any batt min limits 50v below that
Has thanked: 75 times
Been thanked: 306 times
Re: [WIP] BMW Z3
I've sent you a bin with a change from Tom, possibly fixing this limit issue. God Speed
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
andybpowell
Re: [WIP] BMW Z3
Bigpie wrote: Wed Feb 28, 2024 1:17 pm I've sent you a bin with a change from Tom, possibly fixing this limit issue. God Speed
well I've just eaten so I wont have to eat hospital food anytime soon if I end up there :lol:
Has thanked: 106 times
Been thanked: 226 times
Re: [WIP] BMW Z3
Thanks Jamie, Andy please keep to a conservatie throttle max for now, we want to see if the IDC levels off as quick now. Should theoretically not be the case so the torque will carry on for longer.
andybpowell
Re: [WIP] BMW Z3
tom91 wrote: Wed Feb 28, 2024 1:22 pm Thanks Jamie, Andy please keep to a conservatie throttle max for now, we want to see if the IDC levels off as quick now. Should theoretically not be the case so the torque will carry on for longer.
Too late :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: bloody awesome
After these 2 runs I floored it and span the wheels half way up the road, my neighbours are so pissed :o most of the juddering has gone I feel a lot of what's left may be the backlash in my diff I'm not sure it will last much longer with that torque :lol:
Re: [WIP] BMW Z3
Now thats more then double the current draw, and no flat point insight on the current draw. Better get the car ready for some higher speed acceleration tests. :)
andybpowell
Re: [WIP] BMW Z3
tom91 wrote: Wed Feb 28, 2024 1:51 pm Now thats more then double the current draw, and no flat point insight on the current draw. Better get the car ready for some higher speed acceleration tests. :)
I'm trying to find a new diff right now :)
You and Jamie are a pair of absolute legends :D
Re: [WIP] BMW Z3
We. Need. Video.
VW Beetle 2003
Outlander charger
Chademo Charging
andybpowell
Re: [WIP] BMW Z3
Bigpie wrote: Wed Feb 28, 2024 1:56 pmWe. Need. Video.
what of me screeming like a girl wheel spinning up the road :lol:
Re: [WIP] BMW Z3
sounds perfect, that was only 30% throttle too?
VW Beetle 2003
Outlander charger
Chademo Charging
andybpowell
Re: [WIP] BMW Z3
In all seriousness I really need to change the diff before it disintegrates, it sounds bad :(
andybpowell
Re: [WIP] BMW Z3
Bigpie wrote: Wed Feb 28, 2024 2:00 pm sounds perfect, that was only 30% throttle too?
the damn thing just took of like a bat out of hell I can't wait to do some real testing :D that was a real shove in the back
Re: [WIP] BMW Z3
andybpowell wrote: Wed Feb 28, 2024 2:04 pm the damn thing just took of like a bat out of hell I can't wait to do some real testing :D that was a real shove in the back
Be great if you could get the car sorted now you know she is dangerous. Then you can do on the move acceleration tests as those are more interesting from a performance point of view.
Re: [WIP] BMW Z3
andybpowell wrote: Wed Feb 28, 2024 2:03 pm In all seriousness I really need to change the diff before it disintegrates, it sounds bad :(
Give it a send off with a bang?
VW Beetle 2003
Outlander charger
Chademo Charging
andybpowell
Re: [WIP] BMW Z3
Bigpie wrote: Wed Feb 28, 2024 2:10 pm Give it a send off with a bang?
That would be foolish as I'd have to get it home from wherever it decided to die I'll leave that sort of thing to someone silly enough to get trapped under his own bonnet ;) do you know anyone like that ?
Re: [WIP] BMW Z3
I'm not sure that I do 8-)
VW Beetle 2003
Outlander charger
Chademo Charging
andybpowell
Re: [WIP] BMW Z3
having major hassle trying to get a diff with a better ratio, current is 3.45 best straight swap I can get is a 3.38 not a massive improvment but I want to get on as my mot is due in 6 weeks so I'm probably going to do it anyway
crasbe
Has thanked: 44 times
Been thanked: 109 times
Re: [WIP] BMW Z3
Post by crasbe »
The internet says that the diff is the same as in the E36 compact, which should be available (somewhat) plentiful. At least compared to Z3 differentials.
The compact had 3.07 and 3.23 in the 323ti and 323tiA (which stands for Automatic I guess?): http://www.e36racing.de/differenzial.php
andybpowell
Re: [WIP] BMW Z3
crasbe wrote: Thu Feb 29, 2024 3:30 pm The internet says that the diff is the same as in the E36 compact, which should be available (somewhat) plentiful. At least compared to Z3 differentials.
they both used the med case 188 diff
Woodfie
Has thanked: 149 times
Been thanked: 67 times
Re: [WIP] BMW Z3
Post by Woodfie »
Many thanks Guys for all this info. Is so good to see this active experiment in action. These Transmission seem to have lots of potential, on paper before, but this is realizm. Well done..
Am still seeking a 300H inverter, as my attempts with the Prius zvw30 inverter could be needing this solution..
andybpowell
Re: [WIP] BMW Z3
My new diff is on it's way so should be able to get on soon still have to sort out the bms and charging but the weather isn't being very cooperative but I'm hoping to have all of those working and the diff in by the end of the week
andybpowell
Re: [WIP] BMW Z3
now my diff is on the way I'm really tempted to order a lsd for it in fact I'm on the Matt Lewis racing site with it in the basket right now trying to be sensible and really struggling because I really really want it
:lol:
andybpowell
Re: [WIP] BMW Z3
wow just realised this swap from leaf to lexus has taken 5 months so far, where did that go ?
Woodfie
Re: [WIP] BMW Z3
Post by Woodfie »
andybpowell wrote: Sun Mar 03, 2024 5:26 pm wow just realised this swap from leaf to lexus has taken 5 months so far, where did that go ?
Time flies like an arrow, Fruit flies like a banana.
You are making good progress, well done .
andybpowell
Re: [WIP] BMW Z3
New Diff has arrived and I havent even unboxed it yet as wouldn't you know it, it's pissing down outside :(
