Bintang 5 wrote: ↑Thu Aug 20, 2020 11:07 pm
I am planning to get completely rid of the original powertrain and replace it with a small Tesla drive unit.
Waiting for the open inverter Solution for Tesla Model 3...
Regarding battery, these PHEV BMW packs seem to be a good source. Did you use the complete pack or got the modules out of the pack?
Heiko Fleck is often mentioned. Yet not intending to buy anything there as I plan to use mainly used OEM parts...
Might ask him anyway.
Are EV-OEM parts automatically considered as "certified" for the use in a conversion? I don't assume you get any kind of documentation for these parts?
Really good choice. Back when i got the Leaf motor it was really the only affordable choice here, so i went for it. Now there are more solutions available.
Yes i used complete Ampera battery with original BMS modules. I used SimpBMS as a mediator, but i figure i could make the BECM work for me also. Sadly i hadnt had the time or the will to try.
Heiko can mediate at TUV Sud. As i am not German citizen i need someone to apply for me. For a nominal fee
As i understand Motor-inverter combination has been tested for EMC and EMI. If you use the same OEM combo you should be good. I really think guys at TUV have a database with inverter, motor, charger and DCDC part numbers which are tied to their respective EMC codes. I had to send evidence of my inverter front sticker which was not visible at the time of inspection. For charger they also demand either CE mark or OEM certificate references.
For Webasto heater they took photo of the front face with CE mark.
Brake vacuum booster needs to have a CE also.
If you use EHPAS pump you need to demonstrate it came from another vehicle. Usually a photo of part number and installation is good enough.
DCDC, well i would go for Tesla stuff any day, but Ampera DCDC was available and cheap. It has CE mark and all.
They are quite thorough. You need to have battery boxes sealed tight. Cover needs to be electrically insulated. Boxes need to have gas venting possible. Batteries need to be firmly mounted and they go about checking that for every box!
Every HV cable needs to in an orange sleeve and fixed by grommet when passing through a bulkhead.
https://leafdriveblog.wordpress.com/202 ... -findings/
