J1979, ISO15765, OBD-II
- catphish
- Has thanked: 94 times
- Been thanked: 179 times
I'm looking at options to display my vehicle data on a display in my car, ideally an Android tablet. The simplest way to do this would seem to the the Torque app. Does Openinverter have any support for J1979 / ISO15765 / OBD-II, or would I need my VCU to buffer cache the data and provide the OBD-II responses?
- Has thanked: 105 times
- Been thanked: 217 times
Re: J1979, ISO15765, OBD-II
OBD-2 is very straight forward luckily. As it is a query response type structure.
I modified this arduino code to work for some testing: https://github.com/spoonieau/OBD2-ECU-Simulator
Orion is quite detailed on how they done it too. https://www.orionbms.com/general/retrie ... d2-canbus/
- catphish
Yep, shouldn't be too tricky to implement, and I guess it makes sense to have a single device collect the data and handle all OBD2 queries.
I do not know if the Torque app allows you to connect to multiple ECUs, so you could be forced into collecting or atleast gatewaying.
- Has thanked: 160 times
- Been thanked: 1037 times
I am currently refactoring the CAN module anyway to separate the hardware from the logic part, so I might add an OBD2 layer as well.
I'm kind of tired of my android radio not reliably connecting via wifi so this would be a good alternative.
- catphish
My thought was that if each ECU only responds to requests it knows the answer to, and there's no overlap, there shouldn't be a problem with them all using the same address.
It would be fantastic if this is something that can be added. I love the web interface for programming / tuning / debugging, but once the vehicle is up and running, OBD2 would likely be the better option, at least for monitoring. The ESP8266 drives me a little mad.
- Been thanked: 3 times
I just sent a PR to add OBD2 support to the stm32-vcu code: https://github.com/damienmaguire/Stm32-vcu/pull/57
I just created a custom service that maps PID to Param num and let the displaying app deal with formatting it. This was a bit tricky since there appears to be some pretty bad bugs in the Torque code for dealing with signed 32 bit values, but I found a way to brute force it with the basics that do work.
I also mapped a few of the really basic SAE pids to existing params, but we could certainly add more.
- uhi22
- Has thanked: 92 times
- Been thanked: 415 times
The TorquePro definitely connects to multiple ECUs. I use it in Hyundai Ioniq. The gateway is just routing the requests and responses to/from the other buses. The gateway does not collect the data autonomously.
BTW: ISO15765 is only the transport layer, which makes it possible to transport up to 4095 bytes per PDU. Above is the diagnostic protocol, in these days usually UDS. I think it makes sense to implement this, it is a standard. In one of Damiens videos I even saw that he used ODIS as counterpart on PC side. This is a standard tool for measurement, parametrization, dealing with error memory and running io-control. (I have no idea where he found an unlocked version.)
Does every electric vehicle have a standard pid list for obd2? Or is there a different pid list for the per vehicle? Do you have an example
