Bender ISO165C for Isolation Monitoring
DrJeff
Post by DrJeff »
I've posted some prototype and demo code to my github to use the Bender ISO165C unit.
https://github.com/DrJeffCooke/IsolationMonitorBender
The unit measures the isolation of an EV system (effectiveness in kOhms of the insulation) and also two high voltage readings. It then reports these in CAN.
https://www.benderinc.com/products/grou ... -iso165c-1
I'm using the insulation monitoring as a safety measure and the high voltage readings as a means of monitoring that the high voltage contactors are working as expected (in particular that the pre-charge contactor has operated correctly before the main positive contactor is closed).
I thought this might be an interesting set of data for those working on conversions and interested in additional safety measures. I still have some more testing to do to confirm that the ISO165C will work while fully integrated with the Tesla Charger and Tesla Drive Unit. I don't anticipate issues, but the Bender documentation does state that more than one ISO165C units would be an issue.
If I were doing this again I would have selected the ISO165C-1 which can output directly to a warning and fault line. Using the ISO165C you have to interpret CAN frames to detect a fault or warning condition. The units also come with pre-programmed CAN speeds which may be a limitation. Thankfully my unit runs at 500kps (contrary to the documentation) which is the speed the TesLorean CAN network is running at.
Jeff
boekel
Been thanked: 11 times
Re: Bender ISO165C for Isolation Monitoring
Post by boekel »
Pretty cool unit. do you know prices?
SciroccoEV
Been thanked: 15 times
Post by SciroccoEV »
I talked to them at CENEX LCV and the prices were reasonable, sub £200 as I recall.
boekel
Post by boekel »
These seem to have disappeared, does anyone know if they stopped making them or just put them on the 'not public' list?
Has thanked: 75 times
Been thanked: 304 times
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
boekel
Post by boekel »
Bigpie wrote: Wed Sep 20, 2023 11:20 am https://www.benderinc.com/products/grou ... 04-series/ what you're looking for?
unfortunately that is missing much of the features (CANbus, 2x voltage measuring..)
