Broken Software! Is there a master file?
Hi all,
I have used Zero EV/Fellten SDUs in the past, and they suggested that I could use an open inverter board with their software.
Unfortunately, I tried and instead, corrupted the software on the Open Inverter board. Now, when I connect to the board's wifi, I get the two lines asking to upload software or firmware.
How do I get back to accessing all the parameters like i had when the board was delivered? Does anyone have a file and a method please?
Thanks in advance
Thanks in advance
- nubster
- Has thanked: 38 times
- Been thanked: 9 times
Re: Broken Software! Is there a master file?
I wrote up a how-to document here based on my experience from this post.
The process for flashing the STM32 and ESP32/ESP8266 modules should be the same or similar, but if you're trying to reload the Zero EV/Felton software, you'll need to use the corresponding firmware files instead.
You can also find attached the SDU parameters that came preloaded on my last board.
- sdu-params-preloaded-from-webshop.json
- (1.21 KiB) Downloaded 70 times
Car/EV enthusiast, maker, builder, software engineer, and lifelong student of all things interesting.
Owner | Founder: Westside EV
YouTube Channel
YouTube Channel
Thank you,
Is it possible to do any of this over wifi? When IU log onto the IP address i see this...
nubster wrote: ↑Sun Aug 06, 2023 10:22 pm I wrote up a how-to document here based on my experience from this post.
- Has thanked: 172 times
- Been thanked: 1089 times
This means the file system is not flashed.
I think it is easiest to use a software called curl
See here: viewtopic.php?p=3893#p3893
Necessary files are here: https://github.com/jsphuebner/esp8266-w ... aster/data
And yes you can do it over wifi.
Nearly there!
I'm not a developer, so curl is very alien to me, I need a bit of spoon feeding.
I can't find a way to get curl on my mac. When I try searching online, I get some terminal instructions, but nothing seems to work when I try it.
Nearly there!
johu wrote: ↑Thu Aug 31, 2023 7:58 am This means the file system is not flashed.
Do you have the version with soldered ESP32 module?
If so you can upload the attached file with the second Browse button (FileSystem)
- spiffs-esp32.bin
- (1.44 MiB) Downloaded 75 times
I'm afraid I can't remember, but I think the version was soldered.
Order 1180
"Tesla™ SDU drop-in logic board (community edition)
- Checkbox: Include 2 MLX91209 c.."
I'll try what you've suggested
Order 1180
I tried uploading that file and got the following error:
Update error: Bad Size Given
Does that give you any clues? Can I try something else?
Note to myself: only suggest what you've tried yourself
So no, some bug prevents uploading that bin file.
Maybe have someone do it for you? https://openinverter.org/wiki/Application_Support
I succeeded with platformio, so you'd need to install that on your Mac, then download this: https://github.com/Pete9008/esp32-web-i ... /tree/johu (Code -> Download Zip),
- extract zip
- open platformio..ini in an editor
- Remove line "upload_flags" and the 2 lines after and replace it by line "upload_port = 192.168.4.1"
- open a console in the directory where platformio.ini resides
- type "pio run --target uploadfs"
- extract zip
OK, I got as far as replacing the line in the text file.
Can I have a little more guidance on the steps "- open a console in the directory where platformio.ini resides" and "- type "pio run --target uploadfs""
I've opened console but I'm not sure where to go from there. I assume from the edited text file, now containing the Inverter IP; it will launch the file and attempt to connect to the inverter if I'm on it's wifi.
johu wrote: ↑Thu Aug 31, 2023 6:25 pm Note to myself: only suggest what you've tried yourself
- extract zip
How do i use consol to upload this text file? Can you help?
I don't know how to rewrite this to become clearer. Also I've never used a Mac so I don't know if what I mean is even called "console" there
Try searching the web for "platformio mac" or "vscode mac"
Well, to be honest this was harder than I thought.
Did a session with Kit and it took me one hour to get going at all. I ended up downloading python for windows. That only installed if you uncheck the "Admin" option"
Then I installed platformio via pip
Then I had to modify the line endings of platformio.ini to be windowsy and also changed the port to 192.168.4.1 like said above
And then ran
Then disabled the windows firewall and ran it again
Needless to say that every step took ages But in the end all was working
python -m pip install -U platformio
And then ran
