Hi, I'm running Tesla model 3 75kwh battery as a powerwall. I've ran into an issue where the bms gives a little over 9v for the HV voltage, also amps are over 3000.
SOC wont also rise from 9%.
Cell voltage seems ok and so is balancing. Friend suggested a bad shunt, but replacing didn't help.
Few other have it running ok on their setup. Btw my model 3 battery is drom 2020.
Any idea what could cause this?
[01]3.529V [02]3.5295V [03]3.529V [04]3.5281V [05]3.53V [06]3.5286V [07]3.5302V [08]3.5298V [09]3.5281V [10]3.5288V [11]3.5294V [12]3.5283V
[13]3.5284V [14]3.5274V [15]3.5269V [16]3.528V [17]3.5283V [18]3.528V [19]3.5273V [20]3.5252V [21]3.5284V [22]3.5283V [23]3.5278V [24]3.5291V
[25]3.5285V [26]3.529V [27]3.5308V [28]3.5294V [29]3.5301V [30]3.5298V [31]3.5294V [32]3.5291V [33]3.5304V [34]3.5292V [35]3.5292V [36]3.5272V
[37]3.5273V [38]3.5281V [39]3.5272V [40]3.5279V [41]3.5275V [42]3.5275V [43]3.5257V [44]3.5268V [45]3.527V [46]3.5279V [47]3.5277V [48]3.5274V
[49]3.5268V [50]3.5287V [51]3.5283V [52]3.5284V [53]3.5283V [54]3.5275V [55]3.5287V [56]3.5287V [57]3.5289V [58]3.5289V [59]3.529V [60]3.5289V
[61]3.5288V [62]3.5274V [63]3.5284V [64]3.5281V [65]3.528V [66]3.5284V [67]3.528V [68]3.5284V [69]3.5291V [70]3.5281V [71]3.5288V [72]3.5284V
[73]3.528V [74]3.5292V [75]3.5284V [76]3.5301V [77]3.5295V [78]3.5297V [79]3.5292V [80]3.5299V [81]3.5303V [82]3.5285V [83]3.5314V [84]3.53V
[85]3.5282V [86]3.5283V [87]3.5287V [88]3.529V [89]3.5288V [90]3.5281V [91]3.528V [92]3.5284V [93]3.5263V [94]3.5292V [95]3.5266V [96]3.5285V
battery_voltage : 9.5 V battery_amps : 3276.8 A battery_charge_time_remaining : 409.5 min
min_voltage : 240.0 V max_discharge_current : 0.0 KW max_charge_current : 0.0 A
max_voltage : 403.2 V regenerative_limit : 0.0 KWh discharge_limit : 0.0 KWh
max_heat_park : 0.0 KWh hvac_max_power : 0.0 KWh soc_max : 12.8 %
soc_ave : 12.4 % soc_vi : 9.8 % soc_min : 11.5 %
bms_bat_temp_pct : 36.4 C bat_beginning_of_life : 77.8 KWh high_voltage : 9.5214 V
low_voltage : 12.109 V output_current : 0.0 A soc : 9 %
energy_buffer : 3.2 KWh energy_to_charge_complete : 54.0 KWh expected_energy_remaining : 6.6000 KWh
full_charge_complete : 0 ideal_energy_remaining : 6.6000 KWh nominal_energy_remaining : 7.0 KWh
nominal_full_pack_energy : 71.8 KWh total_discharge : 20947. KWh total_charge : 21816. KWh
regen_charge_total : 2817.0 KWh drive_discharge_total : 19569. KWh discharge_total_module1 : 5072.2 KWh
charge_total_module1 : 5279.8 KWh ac_charge_total_module1 : 3151.3 KWh dc_charge_total_module1 : 1445.6 KWh
discharge_total_module2 : 5408.8 KWh charge_total_module2 : 5629.3 KWh ac_charge_totalmodule2 : 3349.6 KWh
dc_charge_total_module2 : 1553.7 KWh discharge_total_module3 : 5407.8 KWh charge_total_module3 : 5630.0 KWh
ac_charge_total_module3 : 3349.6 KWh dc_charge_total_module3 : 1554.4 KWh discharge_total_module4 : 5071.7 KWh
charge_total_module4 : 5280.1 KWh ac_charge_total_module4 : 3151.5 KWh dc_charge_total_module4 : 1445.5 KWh
ac_charger_total : 12997. KWh dc_charger_total : 6001.1 KWh
