Nissan Leaf Motor Specs for FOC
marelmaxx
Post by marelmaxx »
I'm getting started with the Nissan Leaf motor.
Are there specs available for things like Rs, Ls, Flux, Back EMF constant, power factor, efficiency, etc.?
I've looked through the resources here, but so far have not found them. I found on one page "openinverter rev3 board pre programmed with leaf motor tune", and maybe the tune has the info, but I'm not sure where to get that to check it out.
Thanks!
Pete9008
Has thanked: 102 times
Been thanked: 347 times
Re: Nissan Leaf Motor Specs for FOC
Post by Pete9008 »
Can't help with all of those but you can find some of them here https://openinverter.org/forum/viewto ... #p52763
marelmaxx
Post by marelmaxx »
Thank you!
That should be useful.
Also, the motor inertia is another spec that I am searching for.
