Honda ima and his abilities An old beetle
Romale
Has thanked: 214 times
Been thanked: 49 times
Post by Romale »
Hello, people!
I remember there were attempts to work with small IMA inverters more than once, and someone considered them untenable.
I will show in this topic what this wonderful little controller + v3 board is really capable of!
So, the first: a motorcycle made of beetle, 72 volts.
Second: a car weighing 1.4 tons, 140 volts.
evil neodymium :twisted:
Romale
Re: Honda ima and his abilities An old beetle
Post by Romale »
Later, I will add something else that will travel on this controller. If you are interested in the settings, feel free to ask.
marcexec
Has thanked: 536 times
Been thanked: 45 times
Post by marcexec »
Cool, what amp limits are you running?
Getting started guide for Celeron55's iPDM56
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
Romale
Post by Romale »
marcexec wrote: Mon Apr 24, 2023 11:20 am Cool, what amp limits are you running?
il1gain 4,09
il2gain 4,09
overcurrent 500
idcmax 300
Romale
Post by Romale »
there is only one wiring for connecting current sensors (they receive power from the native board of the inverter), and only two wires for each power module to control the PWM relative to the total GND, + two wiring for 12 volts of the native board. this is enough for high-quality operation of the inverter.
I also make an external Wi-Fi module using a sealed type-c connector for this, and I completely fill the inverters with a special compound, which makes them protected from immersion in puddles))
Ryclanmoto
Post by Ryclanmoto »
Good afternoon, could you tell me where what is connected to the Honda inverter, where is which wire? thank you in advance
Romale
Post by Romale »
Ryclanmoto wrote: Sat May 20, 2023 1:59 am Good afternoon, could you tell me where what is connected to the Honda inverter, where is which wire? thank you in advance
with this connection, pinswap=4 (pwmout13)
il gain = 4.1
Ryclanmoto
thanks, but don't know how to connect exactly honda insight,fit , how to connect their inverter, you have whatsapp
Romale
Post by Romale »
Ryclanmoto wrote: Sat May 20, 2023 11:33 am thanks, but don't know how to connect exactly honda insight,fit , how to connect their inverter, you have whatsapp
so the honda fit has another inverter. it does not contain logic and it needs to immediately send control signals to its native nest. he also has external current sensors, not very convenient.
Romale
Post by Romale »
I have an inverter from fit. I haven't dealt with it yet. later I will make it workable and add information here
Romale
Post by Romale »
in the same topic, an inverter from honda civic
Ryclanmoto
Romale wrote: Sat May 20, 2023 12:38 pm I have an inverter from fit. I haven't dealt with it yet. later I will make it workable and add information here
cool, we are waiting for the article, I think a lot of people would be interested in the fit inverter and insight
Romale
Post by Romale »
update!
I tested an ima inverter from 250 volts and it didn't burn out, up to 250 amps of battery current!
this is a great power for such a small inverter!!
Leo M
Post by Leo M »
700км пробег работает как часы. Пока без температуры инвертора и вольтметра , но это скоро решим , пока лень морочатся))
Leo M
Post by Leo M »
Ссылка на телегу на ютубе под видео..
Leo M
Post by Leo M »
Этот инвертор неудобен в переделке. Не вижу смысла с ним заморачиваться.
Ryclanmoto
Leo M wrote: Tue Jul 04, 2023 4:26 am Этот инвертор неудобен в переделке. Не вижу смысла с ним заморачиваться.
Why did you decide so, I think many will be interested in the inverter honda insight, fit Due to its compactness and cheapness, and the connection is easy through the connector chip
Leo M
Post by Leo M »
Ryclanmoto wrote: Sat Jul 08, 2023 9:37 am Why did you decide so, I think many will be interested in the inverter honda insight, fit Due to its compactness and cheapness, and the connection is easy through the connector chip
)))) хотелось бы на это посмотреть… Коль это так легко )))
Ryclanmoto
Everything has its time, at least managed to move in the project with the help of arduine, twist
Has thanked: 157 times
Been thanked: 1025 times
Leo M wrote: Sun Jul 09, 2023 4:26 am )))) хотелось бы на это посмотреть… Коль это так легко )))
Can you pipe everything through a translator to English please.
Romale
Post by Romale »
250 volts (60s li-ion battery). 40+ kW of power! the car is 1500 kg! 130 km / h.
as a motor, a generator with a Nissan Serena. as a ima inverter.
Very nice :)
Why does it have 2 fuel gauges? Why did you need to pull over on the highway? Are you running in field weakening?
Romale
Post by Romale »
no, I did not use field attenuation.
two devices are one fuel level, and the second is an economizer (the device is connected to the vacuum on the intake manifold of the internal combustion engine and shows how economically you drive)
Romale
Post by Romale »
johu wrote: Sun Oct 15, 2023 4:16 pm Very nice :)
I stopped to shift the gear to a lower gear and test the maximum speed in this gear.
Thank you :)
I thought something went wrong because of the noises.
