I can send mine to you no issue. PM me an address and I'll get it in the post
can id´s 4 Gear Selector
- Has thanked: 286 times
- Been thanked: 65 times
Re: can id´s 4 Gear Selector
- Has thanked: 43 times
- Been thanked: 110 times
That seems to fit with the logs I have for my GSM. Have you tried the sketch I posted?nkiernan wrote: ↑Wed Apr 05, 2023 8:06 pm Hope this can help a bit. I tested both the new Gen1 and Gen2 sketches on my unit. So like VanGogh, neither is getting any action from the selector. However, from previously running some of Tom's CAN logs from Savvycan, the knob did raise but wouldn't retract. When Gen1 sketch started running, the knob did retract but wouldn't move after that. Connections as per Tom's post above, add/remove ignition brings on the back lights etc.
So connected savvycan and captured the log below. This starts with ignition off and I apply ignition on after a few seconds in the log. Sharing now in case its any use, but I need to compare this capture back to some of Tom's logs
Some sample output in the Arduino serial monitor:
386688,0x3F3,false,8, 0x7C, 0x24, 0x05, 0x08, 0xFE, 0xFF, 0x01, 0x00 386709,0x3F3,false,8, 0x7C, 0x24, 0x06, 0x09, 0xFE, 0xFF, 0x01, 0x00 386731,0x3F3,false,8, 0x7C, 0x24, 0x07, 0x0A, 0xFE, 0xFF, 0x01, 0x00 386752,0x3F3,false,8, 0x7C, 0x24, 0x08, 0x0B, 0xFE, 0xFF, 0x01, 0x00 386774,0x3F3,false,8, 0x7C, 0x24, 0x09, 0x0C, 0xFE, 0xFF, 0x01, 0x00 386795,0x3F3,false,8, 0x7C, 0x24, 0x0A, 0x0D, 0xFE, 0xFF, 0x01, 0x00 386816,0x3F3,false,8, 0x7C, 0x24, 0x0B, 0x0E, 0xFE, 0xFF, 0x01, 0x00 386837,0x3F3,false,8, 0x7C, 0x24, 0x0C, 0x0F, 0xFE, 0xFF, 0x01, 0x00 386859,0x3F3,false,8, 0x7C, 0x24, 0x0D, 0x10, 0xFE, 0xFF, 0x01, 0x00 386880,0x3F3,false,8, 0x7C, 0x24, 0x0E, 0x11, 0xFE, 0xFF, 0x01, 0x00 386902,0x3F3,false,8, 0x7C, 0x24, 0x00, 0x03, 0xFE, 0xFF, 0x01, 0x00 386923,0x3F3,false,8, 0x7C, 0x24, 0x01, 0x04, 0xFE, 0xFF, 0x01, 0x00
- Has thanked: 106 times
- Been thanked: 223 times
Can you get it to raise with playing back only the 0x3F3 of https://github.com/Tom-evnut/Land-Rover ... 20knob.csv
If this work and then P illuminates I can review my code as there is one slight "difference" I have seen in logs that would be good to try.
In park the counter skips 2 and 3, my Gen 1 and LRBen's units do not care about this though.
Maybe we should send a static message for IGN-ON emulation before sending a message with ID 0x3F3?
Sorry. I realized that these libraries are for the board Arduino DUE. Do you have a sketch for Nano?
Good question! I previously tested your code and it partially worked for me but knob would not retract (i do think it raised, and rotated though). But that was before I knew about the park input signal on pin 14 so I will retest that this evening. thanks for the reminder
I will check this evening. Previously playing back some of the logs did raise it and allow it to turn but without lights and it wouldn't retact etc. WIll also retest LRBen's code now I know about the park input signal requirementtom91 wrote: ↑Wed Apr 05, 2023 9:25 pm Can you get it to raise with playing back only the 0x3F3 of https://github.com/Tom-evnut/Land-Rover ... 20knob.csv
I'm going crazy!!! Bought a new GSM JLR EH22-7E453-AB. Uploaded Gen2 sketch to Arduino nano. Knob does not leave when sending 's'.
Connection: PC - USB - Arduino Nano - MCP2515 - CAN GSM.
What's wrong? Please tell me
Connection GSM:
1 - 12V,
2 - 12V (IGN),
5 - CAN H,
6 - CAN L,
10 -12V,
12 -Ground
That part number looks like mine which runs on the Gen 1 canbus messages. Try that script.VanGogh wrote: ↑Thu Apr 06, 2023 11:14 am I'm going crazy!!! Bought a new GSM JLR EH22-7E453-AB. Uploaded Gen2 sketch to Arduino nano. Knob does not leave when sending 's'.
Connection: PC - USB - Arduino Nano - MCP2515 - CAN GSM.What's wrong? Please tell meCode: Select all
Connection GSM: 1 - 12V, 2 - 12V (IGN), 5 - CAN H, 6 - CAN L, 10 -12V, 12 -Ground
Unfortunately I don't have a Nano version for my script. But it's fairly basic so you should be able to port it over, or write your own based on that or Tom's code.
This is a Gen1 as this is an old knob just like LRBen is using.
If you do not answer our questions and keep doing your own thing we are not going to help you.
Sorry. Could you please repeat your questions? I'm completely confused.
I use MCP2515 like this. It has 120 Om builtin resisror and jamper
https://www.ebay.com/itm/404205629787?h ... BMjLPW5uph
If I measure the resistance on a сan bus without mcp 2515 and ignition, then the tester writes 41 kOhm. If you turn on the ignition, then writes 60 MΩ. If I connect to mcp 2515 with a jumper without ignition - 120 Ohm. I turn on the ignition - 0 ohm.
Use Gen 1 code on this knob.
Again if you need more help do as asked.
tom91 wrote: ↑Wed Apr 05, 2023 6:00 pm a
You need to do the following:
Option 1
1. Have an Arduino setup running the code as I posted on Github for the Gen 1 JLR GSM
2. Have another device (can be another arduino setup) reading the canbus between the Arduino and GSM
3. Log this data and share it here so I can review it.
Option 2
1. Put the GSM back to gethor
2. Put the GSM in a box
3. Post it to me
YEHAAAAAAA !!!! The second GSM works with Gen1
Knob rotates and LEDs light up But the first doesn't work at all (9X23- 7E453-DA)
Did some more testing this evening. Starting off, the selector was raised from previous tests when I couldn't get it to retract.
I played back all the Gen1 and Gen2 CAN logs using savvycan, and the Gen1 logs periodically activated the internal lock, changed the P-R-N-D-S lights but none lowered the selector when ignition signal removed.
Changed over to a DUE and LRBen's code. This worked this time. Previously I didn't have 12V+ at the park input (pin 14 on the 22 way connector). This signal is required when ignition signal is removed before the selector retracts. I also see the lights delay going from R back to P. I'll take a look at this and the internal lock as a serial monitor input test.
Log below running LRBen's code (ign on, P-R-N-D-S-D-N-R-P, ignition off)
Thank you Tom and LRBen for your work on this, great to see this unit working now
My joy was short lived. It was possible to launch only 2-3 times. 2 days I can not understand the reason for the failure to turn on. Replaced all wires, removed arduino dupont and soldered mcp2515 with arduino outputs. Replaced the TJA1050 chip but nothing. Sometimes the green light comes on.
Nothing helps.
Tomorrow I will buy another mcp2515 module and read the data between the first installation and the GSM. I'll post the log here.
Hi.
I connected another NodeMCU with mcp2515 in parallel and read data between Aruino with mcp2515 and the GSM. Attached are 2 logs from different GSM. It seems to me that the Park wire (14 pin for a 22 pin connector or 10 pin for a 12 pin connector) is not working.
- Jaguar.txt
- (9.55 KiB) Downloaded 56 times
- LandRover.txt
- (5.64 KiB) Downloaded 66 times
I give up. I do not understand what is going on. Sometimes the backlight of the module turns on by itself. It may turn off immediately or work for a long time. I only had one successful launch when everything worked. After 3 days, the knob rose once and the Parking LED lit up, but the knob did not move. Then 2 times the knob rose without highlighting "P". Now it has completely stopped rising, only the backlight sometimes blinks. Maybe a problem with wires and stray currents that interfere with the can bus?
Hi guys. I adapted LRBen's code for Arduino Uno with CAN shield. Now everything works, but there are a few nuances. When I return the knob from the R to P position, the program crashes for a few seconds and then it works again. Sometimes the situation is the same with position S.
Could you look at the code and help me? I also don't know how to add a brake pedal to lock/unlock the knob.
A small video review of the module:
https://drive.google.com/file/d/1IpKJz6 ... sp=sharing
- GSM_jaguar.ino
- (2.6 KiB) Downloaded 58 times
I have the exact same behavior with my setup and code regarding the stutter when changing to P and sometimes S. Never looked into it at the time since it would have been functional still. Unfortunately the project it's going into is in a que so I won't have time to look into it more until the winter I expect.VanGogh wrote: ↑Wed Jul 12, 2023 4:29 pm Hi guys. I adapted LRBen's code for Arduino Uno with CAN shield. Now everything works, but there are a few nuances. When I return the knob from the R to P position, the program crashes for a few seconds and then it works again. Sometimes the situation is the same with position S.
What do you mean by brake pedal?
I have now checked this code with another GSM and the knob goes up and down, but the unlock does not work
Now the knob rotates freely. But in the car, it is locked and only when the brake pedal is pressed does the knob unlock. How to implement it? What data needs to be sent to the CAN bus?
