E-tron HVJB
RetroZero
Has thanked: 347 times
Been thanked: 44 times
E-tron HVJB
Post by RetroZero »
Hi there folks,doing a breakdown of an E-Tron HVJB.
It has an isolation fault (intermittantly), so hope the tear down reveals something.
In any case, I hope this helps with overall builds.
The unit weights about 15kgs!
It contains 4 HV ETE Relays
There are 3 main HV Fuses
There is an internal control unit monitoring various HV values and controling precharge relay
There is another circuit board connected directly onto MainPositive HV Relay.
There ia an added junction for what I am yet to confirm is for the Rear Inverter/motor.
There is also another junction for the PTC, AC and Charger - again to be confirmed.
I hope to locate the Pyrofuse to understand the safety circuits better too.
Enjoy
EV_Builder
Has thanked: 16 times
Been thanked: 33 times
Re: E-tron HVJB
Post by EV_Builder »
Any chance you make a zoom picture of that square ic on first & second picture; off the current sensor and hv sense board?
RetroZero
Re: E-tron HVJB
Post by RetroZero »
Decided to remove the sensing board. Hope the pictures make sense. Would this be audi's version of isabellenhutte?
EV_Builder
Re: E-tron HVJB
Can you read the "middle" chip? and post it here? i miss a tiny bit to read it.
RetroZero
Re: E-tron HVJB
Post by RetroZero »
:ugeek: So , out with magnifying glass and cross eyes
These are references for sensing board.
On a side note, this board connects to the 'main internal board' which will be in the next post.
Is this some overkill, or just how important voltage sensing, isolation and contacter controle is?
RetroZero
Re: E-tron HVJB
Post by RetroZero »
This is the main contacter controle board inside the HVJB.
It has 10 wires from the outside world, 2 of which are CAN
EV_Builder
Re: E-tron HVJB
RetroZero wrote: Wed Jan 18, 2023 12:39 pm Is this some overkill, or just how important voltage sensing, isolation and contacter controle is?
I think both is true, but one wants high safety standards.
RetroZero
Re: E-tron HVJB
Post by RetroZero »
Did some poking about with a multieter and marker pen. Some interesting findings.
There are 2 circuit boards monitoring various voltages before and after the 4 HV Contactors.
Since there are 2 inverters/motors, there's lots of doubling up I imagine.
What is most interesting is the "Bridge Board" before Main Positive HV Relay. It seems to have a circuit to monitor isolation/current, as there are 2 sets of wiring going to the Main Board. There is also a "copper bar" welded between 2 bus bars with Tabs that are connected to the circuit board.
I would like to find out how HV Isolation is calculated, as it is a requirement for my build I would need to intergrate. Time for Wiki and Google
RetroZero
Re: E-tron HVJB
Post by RetroZero »
Some more useless info, the main circuit board also has the function of PWM signals to keep the HV Relays closed.
If we want to re-use these contactors, we need to have PWM wizardry as well.
Mitchy
Been thanked: 38 times
Re: E-tron HVJB
Post by Mitchy »
Hey Retro.
Do you happen to have any part# for the two HV plug connectors on the front of the unit? (The large ones)
Or if you’re scraping the unit, I’ll be interested in buying them both from you.
RetroZero
Re: E-tron HVJB
Post by RetroZero »
Sorry just saw your message. Will have to look into it next week. I'm out of town for the moment.
Mitchy
Re: E-tron HVJB
Post by Mitchy »
Hey, No worries. Found them once my Taycan charger port arrived.
They're Rosenburger HVR420's
https://www.rosenberger.com/product/hvr420/
RetroZero
Re: E-tron HVJB
Post by RetroZero »
I'm getting a few bits together to set myself CANning thanks to @gregski and his CAN thread so will be following your progress. Hope to copy off as much of your work to get a VW charger functional. Let me know if you still would like those hv connectors.
RetroZero
Re: E-tron HVJB
Post by RetroZero »
So now that I have SavvyCan running, I hooked up firstly the SX6 main board, which swithes the various HV relays, and then the Shunt board which measures Isolation. Using the Fuzzing mode, I managed to get a few ID's out of them. I hope they can be some use to us for decoding....
Please let me know if this helps in any way, or what I should be logging.
1st Log SX6 Shunt_board.csv
(3.11 MiB) Downloaded 7 times
1st Log SX6 board.csv
(4.21 MiB) Downloaded 8 times
