So the Red Arrow is without a battery. Apart from a 35S1P pack I built from cheap Chinese 32700 LiFePO4 cells that can get the car to the end of my estate and back, at a push
So, looking for a new battery. I feel any sort of PHEV pack will do the trick, although I need to end up with something between 120V and 240V. Less and the precharge circuit will prevent it from running. More and that would be too much of a push on the DC 48V motor. A BMW 530e / 740e pack would be ideal as it has 6 blocks, which I could split up in 3S2P
Staying true to the Red Arrow, a €1,000 EV, the battery needs to be cheap and can not be lead acid. Capacity not that important, even 6-7kWh is more than adequate
What have you? Any suggestions and offers welcome! Feel free to post here or PM me.
