Gen 3 160kw inverter only outputs 125 kw
Zapatero
Has thanked: 27 times
Been thanked: 58 times
Post by Zapatero »
I have installed a Gen3 inverter and it only outputs 125Kw. I kindly like to ask Johannes to paste the line of code here so someone maybe can identify the issue.
johu wrote: ...
Thanks, Philip
Re: Gen 3 160kw inverter only outputs 125 kw
In general the gremlin would be in this file: https://github.com/damienmaguire/Stm32- ... eafinv.cpp
And possibly this line:
final_torque_request = (torquePercent * 2047) / 100.0f;
So maximum request is 2047
dimonlipko
Has thanked: 7 times
Been thanked: 11 times
Post by dimonlipko »
I have the same problem. I add more ID in can bus that need for 160kw inverter, and it start take 550A from battery. But now have problem, that when torque request more than 2047, motor cut power and shaking. If I press pedal slower, motor have full power, but without max torque.
Zapatero
Post by Zapatero »
Are there some can logs out there from a Nissan Leaf with 160Kw where we could see, what exactly is happening there?
dimonlipko
Yes, I have log from leaf 160kw in drive.
Leaf_62kw_160kw_inv_in drive.txt
(215.54 KiB) Downloaded 511 times
Zapatero
Post by Zapatero »
johu wrote: Fri Dec 02, 2022 6:44 am In general the gremlin would be in this file: https://github.com/damienmaguire/Stm32- ... eafinv.cpp
can you please tell me which message contains the value?
Hex-Identifier and Start bit and length.
Then i could check the text file for the values.
Thanks!!!
Zapatero
Post by Zapatero »
Zapatero
Post by Zapatero »
In 1D4 byte 0 and 1 according to the VCU code we're seinding 0xF7 and 0x07.
Seems to be 0x88 most of the time in the can log txt file.
On another website i found it should be 0x6e and 0x6e
// Usually F7, but can have values between 9A...F7 (gen1)
bytes[0] = 0xF7;
// 2016: 6E
// outFrame.data.bytes[0] = 0x6E;
// Usually 07, but can have values between 07...70 (gen1)
bytes[1] = 0x07;
// 2016: 6E
//outFrame.data.bytes[1] = 0x6E;
https://mynissanleaf.com/viewtopic.php? ... &start=190
byte send1D4[8] = {0x6e, 0x6e, 0x00, 0x00, 0x00, 0x44, 0x01, 0x00};
Also looked at the logfile now. Torque request is in bytes[2] and bytes[3] & 0xF0, signed, big endian
So torque = -2048*(bytes[2] & 0x80)/0x80 + (bytes[2] & 0x7F) * 16 + bytes[3] / 16
The largest value I ever see in the logfile is 1360, very stable for a prolonged time, so probably full throttle. Or have I miscalculated somehow and it should be 1360*2?
cloudy
Been thanked: 7 times
Post by cloudy »
Did anyone manage to solve this in the end?
dimonlipko
I still have this problem(
Zapatero
Post by Zapatero »
I still have this problem, too
aesthetect
Has thanked: 4 times
Post by aesthetect »
Is operation smooth and consistent below request of 2047?
I assume this would be the same situation on any complete 160 kW gen 3 motor+inverter? But is a non-issue on 110 kW units?
Zapatero
Post by Zapatero »
Yes, drives perfectly smooth, just only delivers 125 kw
cloudy
Post by cloudy »
You get 125 from the 110?
Zapatero
Post by Zapatero »
cloudy wrote: Sat Mar 25, 2023 2:39 pm You get 125 from the 110?
No, the topic is about the 160kw inverter. How the 110 kw inverter behaves i don't know.
