VW Passat GTE battery balance problem with one module.
tka
Post by tka »
Hi, all.
I have a VW Passat GTE battery.
I can't turn on balancing at CAN address 0x1A55540E and 0x1A55540F. (“module 3“)
I read the feedback balancing status from CAN address 0x1A555403. (“temperature and balancing”)
Modules 1,2,4,5,6,7,8 balancing works fine. I also get feedback of balancing.
Does anyone know why the balancing doesn't turn on with module 3?
Has thanked: 91 times
Been thanked: 517 times
Re: VW Passat GTE battery balance problem with one module.
I had the same with my golf GTE modules. https://github.com/Tom-evnut/VW-bms/pull/2 will fix it.
Has thanked: 330 times
Been thanked: 848 times
This is the case for any of the Gen 1, orange top modules (please correct me if im wrong). On the later modules, not orange tops those addresses are correct.
tka
Post by tka »
Hi
Now the balancing works. (“module 3”)
I changed the following CAN addresses:
0x1A55540E -> 0x1A55541E;
0x1A55540F -> 0x1A55541F;
After this, the balancing started to work.
The case has orange plastic parts. (“Gen 1”)
Thanks for the answers.
