Mitsubishi Outlander PHEV heater
Has thanked: 80 times
Been thanked: 234 times
Re: Mitsubishi Outlander PHEV heater
Zapatero wrote: Wed Sep 21, 2022 9:21 am How hot does the heater get on the outside. Is it ok to mount it close to painted parts?
I'm afraid this could be too close!
As long as it is not touching the parts they will be OK. It didnt go too high for me as i set it up to no more than 55deg.
If there is water in the lines it diesnt get much hotter than your target.
evMacGyver
Has thanked: 21 times
Post by evMacGyver »
Trying to get heat from my 2018/2019 heater.
Sending 0x285 in 10ms interval: 00, 00, 14, 21, 90, FE, 0C, 10
And 0x188 in 100ms interval: 03, 50, A2, 4D, 00, 00, 00, 00, tried [2] 0x32 and [3] 0x40, no difference
In response I get
0x398: 01, 00, 00, 33, 33, 00, 00, 00
[0] is 0x00 when not sending 0x285
[6] is 0x09 when no HV applied
Nothing else changes and no heat. Any ideas?
BMS battery alive
ID 0x285 at 10ms
00,00,14,39,91,FE,0C,10 Driving
00,00,B6,39,91,FE,0C,10 Charging
Heater report
0x398 ID 00 09 00 3B 3B 00 00 00 at 100ms
byte0 goes 00->01 as soon as 0x285h is received.
byte1 seems to be current report (dec)/10
byte3 seems to be inlet temperature (dec-40)
byte4 seems to be outlet temperature (dec-40)
byte7 h70 when HV is <175Vdc, h00 when HV >175Vdc. So 175V seems to be the low-voltage limit.
Heater command 800ms
0x188 03 50 A2 40 00 00 00 00
byte0 status command
byte1 20 to 50 works
byte2 seems to be current command (dec/10)
byte3 30 to 40 works (not 4D)
DUE Code
//I declare variables
uint8_t Htemp = 0;
uint8_t Heatertemp = 0;
//I setup CAN reading
    if(incoming.id==0x398){
      Htemp = incoming.data.bytes[3] ;
      Heatertemp = Htemp-40;
//I use this function and send it at 800ms
void sendCANframeD() { // Heater
       outframe.id = 0x188;            // 0x188 03 50 A2 40 00 00 00 00
        outframe.length = 8;            // Data payload 8 bytes
        outframe.extended = 0;          // Extended addresses - 0=11-bit 1=29bit
        outframe.rtr=1;                 //No request
        if(digitalRead(Heater_pin) == LOW) { // if heater pin is ON
        outframe.data.bytes[0]=0x03; // when 55deg power goes to 0A
        else {
        outframe.data.bytes[0]=0x00;
        outframe.data.bytes[1]=0x50; // 50 works
        if(Heatertemp > 55) { // if temp is higher than 55deg
        outframe.data.bytes[2]=0x00; // when 55deg power goes to 0A
        else if(Heatertemp > 50) { // if temp is higher than 50deg
        outframe.data.bytes[2]=0x32; // seems to be current command (dec/10)
        else {
        outframe.data.bytes[2]=0xA2;
        outframe.data.bytes[3]=0x40; // 40 works
        outframe.data.bytes[4]=0x00; //
        outframe.data.bytes[5]=0x00; //
        outframe.data.bytes[6]=0x00;
        outframe.data.bytes[7]=0x00;
       if(debug) {printFrame(&outframe,1);} //If the debug variable is set, show our transmitted frame
       if(myVars.CANport==0) Can0.sendFrame(outframe);    //Mail it
         else Can1.sendFrame(outframe);
//I call timer command...
Timer4.attachInterrupt(sendCANframeURGENT).start(10000); // This sets an interrupt time to send an URGENT CAN frame every 10ms.
//To send this function....
void sendCANframeURGENT() {
        outframe.id = 0x285;            // 0x285 00,00,14,39,91,FE,0C,10 Driving
        outframe.data.bytes[1]=0x00;
        if(digitalRead(PP_pin) == HIGH) { // we are driving, no EVSE connected
        outframe.data.bytes[2]=0x14; // PP EVSE connected signal
        else {
        outframe.data.bytes[2]=0xB6; //if we sense PP signal we are charging
        if(digitalRead(BMS_pin) == HIGH) { // if BMS_pin is high
        outframe.data.bytes[3]=0x39;
        outframe.data.bytes[4]=0x91;
        outframe.data.bytes[5]=0xFE;
        outframe.data.bytes[6]=0x0E;
        outframe.data.bytes[7]=0x10;
        else {
         outframe.data.bytes[3]=0x00;
Any news? Does it work yet?
Did you make a double check with CAN reader on the line, so that you confirm msg is seen by devices online?
evMacGyver
arber333 wrote: Wed Oct 12, 2022 12:54 pm Any news? Does it work yet?
Thank you for quick reply, did try those quickly with no difference. Bus should be ok, same controller controls mitsubishi charger and other devices. And 0x285 is seen by heater as response byte0 changes to 1. Maybe I'll clean most of other code and try only heater, just to be sure.
I have such a bad luck with heaters, first ampera LIN-bus heater and now mitsubishi, both communicates but no heat. Weather is getting colder :(
evMacGyver wrote: Wed Oct 12, 2022 2:06 pm Thank you for quick reply, did try those quickly with no difference. Bus should be ok, same controller controls mitsubishi charger and other devices. And 0x285 is seen by heater as response byte0 changes to 1. Maybe I'll clean most of other code and try only heater, just to be sure.
I had some trouble with feedback loop because i didnt use uint8_t variables for reading CAN report.
Hm... Ampera heater does not work with LIN bus. It is a SWCAN device. A bit different protocol, but still a single wire bus.
You could try it with Macchina M2. I think it has 2x CAN bus, 1x LIN bus and 1x SWCAN transcievers installed.
evMacGyver
arber333 wrote: Wed Oct 12, 2022 7:21 pm I had some trouble with feedback loop because i didnt use uint8_t variables for reading CAN report.
My bad, Ampera Eberspacher is SWCAN indeed. Currently I did not use any conversion on response messages, will investigate more later.
evMacGyver wrote: Wed Oct 12, 2022 7:31 pm My bad, Ampera Eberspacher is SWCAN indeed. Currently I did not use any conversion on response messages, will investigate more later.
OK... if you are pressed for heat i recommend you have a look at dishwasher heaters. It is a 230VAC element setup to provide 1800W. If you use it with 360Vdc i would advise to use two in series for 3600W. Plenty of power, it just needs some regulation. How to shut it off? Use a 20A Nissan precharge relay or similar silver contact HV relay with magnetic inserts.
Then you can use its thermostat switch to turn off 12V for the relay.
Can you try sending 0x285 at 30ms? This is what i am using.
Maybe you have a problem with twisted pair? Since 0x285 is really fast it works but 0x188 wont work because of some noise on the lines. See if you have termination resistor on both sides.
evMacGyver
Thank you for your help! Found the problem - it was me! I trusted my code to be fast enough and used metro timers on the main loop. Savvycan quickly showed timing was waaaay off, moved code to interrupt and now I got heat!! Cheers for everyone who was reverse engineering this heater!
Did quickly try Ampera Eberspacher if it was timing issue also, but it did not produce heat yet, will try more later.
I need to add control valves to coolant circuit, so that I can limit battery heat and use car original webasto again. HV heater draws quite a lot of juice..
evMacGyver wrote: Thu Oct 13, 2022 4:39 pm
Glad we can be of help.
I noticed the same last winter. This is the reason i limited heating to 50deg. Webasto can go to 80deg but that is wasting energy with electric heater.
Still at minus 5deg i noticed process does not go to low power. Its just too cold.
I just had a really lot of work for nothing!
To install my Outlander heater i had to remove front battery box and some other stuff. Talk about exercise!
I had tested the heater with my shop battery 350Vdc before, however when i installed it i couldnt get it to work. I attributed this to incorrect CAN bus wiring. I had twisted one cable in the other way than the rest of them 8-) . But thata was not the only problem it seemed. When i corrected the cable i got good report from heater 0x398 ID 00 00 00 31 31 00 09 00. However when i applied HV nothing changed! I should be getting 0x398 ID 01 00 00 3B 3B 00 00 00 as soon as i applied HV and when 0x285 telegram would run.
B6 seems to indicate HV present.
B0 seems to indicate valid system heartbeat with 0x285 telegram.
My heater B6 does not change when i apply HV and i cant get it to start heating.
Any thoughts as to what else could i got wrong?
EV_Builder
Has thanked: 16 times
Been thanked: 33 times
Post by EV_Builder »
Polarity of HV?
EV_Builder wrote: Wed Nov 30, 2022 7:32 am Polarity of HV?
No, as i used those same lines to power that particular heater in my car last winter.
Also i use solar connectors so there is no way to swap polarity as they are different shape.
I guess i have to content with heater being in fault. But i would like to get some confirmation if anybody knows about byte6 info.
Turbopete
Post by Turbopete »
Bigpie wrote: Wed Nov 10, 2021 4:55 pm https://github.com/jamiejones85/OutlanderHeaterControl can control it, it's hardcoded for 50 degrees and heating on for now, it overshoots the desired temperature but it works.
Please could you tell me which MCP library your using ? Im struggling to get this to compile?
royhen99
Has thanked: 17 times
Been thanked: 107 times
Post by royhen99 »
The library has been updated so it no longer uses getCanId. This is now in the readMsgBuf() function. The examples show what needs to change.
Line 60 also needs to change to this.
while (CAN_OK != CAN.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ))
Has thanked: 75 times
Been thanked: 306 times
I'm now using a RPI Pico (https://github.com/jamiejones85/RPI-PICO-Outlander-HVAC) but for the arduino version
Using library mcp_can at version 1.5.0
Using library SPI at version 1.0
Using library TaskScheduler at version 3.7.0
Using library Wire at version 1.0
Using library Adafruit-GFX-Library at version 1.11.3
Using library Adafruit_BusIO at version 1.14.1
Using library Adafruit_SSD1306 at version 2.5.7
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Turbopete
Post by Turbopete »
Thanks very much! - any reason for switching to raspberry pi?
I was given it :D
VW Beetle 2003
Outlander charger
Chademo Charging
Turbopete
Post by Turbopete »
royhen99 wrote: Fri Dec 16, 2022 12:43 pm The library has been updated so it no longer uses getCanId. This is now in the readMsgBuf() function. The examples show what needs to change.
Any chance you could give me a pointer as to which bits need to change - ive looked through the examples but im very much a beginner in the world of coding and this has me baffled!
royhen99
Post by royhen99 »
As well as line 60 above the following needs changing at the begining of loop. Remove getCanId() and add the declaration of canId and to the call to readMsgBuf. This is at lines 220-230ish.
void loop() {
  long unsigned int canId;
  unsigned char len = 0;
  unsigned char buf[8];
  // put your main code here, to run repeatedly:
  runner.execute();
  if(CAN_MSGAVAIL == CAN.checkReceive())            // check if data coming
        CAN.readMsgBuf(&canId, &len, buf);    // read data,  len: data length, buf: data buf
       //unsigned int canId = CAN.getCanId(); this line can be removed
        if (canId == 0x398) {
Turbopete
Post by Turbopete »
That’s mega thank you!
Turbopete
Post by Turbopete »
Should i be receiving water temperature if HV is not connected? At the moment i just get "No temperature Recieved" - thats with the heater connected up on the bench and no water in it?
Turbopete
Post by Turbopete »
Scratch that last question - i figured out that my code was still wrong! This is the code that i am using now:
#include <mcp_can.h>
#include <SPI.h>
#include <TaskScheduler.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define INVERTPOT true
#define OPENINVERTERCONTACTORS //uncomment to check can bus for Open Inverter opmode for contactors, prevents heating over precharge resistor
#ifdef OPENINVERTERCONTACTORS
unsigned long inverterLastRec;
byte inverterStatus;
#endif
unsigned long temperatureLastRec;
#define MAXTEMP 85
#define MINTEMP 40
unsigned int targetTemperature = 0;
bool enabled = false;
bool hvPresent = false;
bool heating = false;
int power = 20;
int currentTemperature = 0;
const int potPin = A0;
const int ledPin = 3;
char msgString[128];                        // Array to store serial string
#define CAN_INT 2                              // Set INT to pin 2
MCP_CAN CAN(10);                               // Set CS to pin 10
void ms10Task();
void ms100Task();
void ms1000Task();
Task ms10(10, -1, &ms10Task);
Task ms100(100, -1, &ms100Task);
Task ms1000(1000, -1, &ms1000Task);
Scheduler runner;
void setup() {
    Serial.begin(115200);
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
    if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
      Serial.println(F("SSD1306 allocation failed"));
      for(;;); // Don't proceed, loop forever
    displayOff();
    Serial.println("Outlander Heater Control");
    pinMode(ledPin, OUTPUT);
    //while (CAN_OK != CAN.begin(CAN_500KBPS, MCP_8MHz))              // init can bus : baudrate = 500k
    //while (CAN_OK != CAN.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ))
      // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK)
//    Serial.println("MCP2515 Initialized Successfully!");
      Serial.println("CAN BUS Shield init ok!");
  else
//    Serial.println("Error Initializing MCP2515...");
      Serial.println("CAN BUS Shield init fail");
  CAN.setMode(MCP_NORMAL);                     // Set operation mode to normal so the MCP2515 sends acks to received data.
  pinMode(CAN_INT, INPUT);                            // Configuring pin for /INT input
 // Serial.println("MCP2515 Library Receive Example...");
    runner.init();
    runner.addTask(ms10);
    ms10.enable();
    runner.addTask(ms100);
    ms100.enable();
    runner.addTask(ms1000);
    ms1000.enable();
void displayTemperature(void) {
  display.clearDisplay();
  display.setTextSize(3); // Draw 2X-scale text
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(20, 10);
  display.print(currentTemperature);
  display.print("/");
  display.print(targetTemperature);
  if (power == 2) {
      display.fillRect(0, 0, 10, SCREEN_HEIGHT, SSD1306_WHITE);
  } else if (power == 1) {
      display.fillRect(0, SCREEN_HEIGHT/2, 10, SCREEN_HEIGHT, SSD1306_WHITE);
  display.display();      // Show initial text
void displayOff(void) {
  display.setCursor(40, 10);
  display.println(F("Off"));
void ms10Task() {
  //send 0x285
   uint8_t canData[8];
   canData[0] = 0x00;
   canData[1] = 0x00;
   canData[2] = 0x14;
   canData[3] = 0x21;
   canData[4] = 0x90;
   canData[5] = 0xFE;
   canData[6] = 0x0C;
   canData[7] = 0x10;
   CAN.sendMsgBuf(0x285, 0, sizeof(canData), canData);
void ms100Task() {
  int sensorValue = analogRead(potPin);
  if (INVERTPOT) {
    if (sensorValue < 923) {
      enabled = true;
    } else {
      enabled = false;
  } else {
    if (sensorValue > 100) {
      enabled = true;
    } else {
      enabled = false;
  //if heater is not sending feedback, disable it, safety and that
  if (millis() - temperatureLastRec > 1000) {
    enabled = false;
    Serial.println("No Temperature recieved");
  if (INVERTPOT) {
      targetTemperature = map(sensorValue, 1023, 100, MINTEMP, MAXTEMP);
  } else {
      targetTemperature = map(sensorValue, 100, 1023, MINTEMP, MAXTEMP);
    //send 0x188
  bool contactorsClosed = inverterStatus == 0x01;
  if (!contactorsClosed) {
    enabled = false;
  #else
  bool contactorsClosed = true;
  #endif
  digitalWrite(ledPin, enabled);
  if (enabled) {
    displayTemperature();
  } else {
    displayOff();
  if (contactorsClosed && enabled && currentTemperature < targetTemperature) {
   uint8_t canData[8];
   canData[0] = 0x03;
   canData[1] = 0x50;
   canData[3] = 0x4D;
   canData[4] = 0x00;
   canData[5] = 0x00;
   canData[6] = 0x00;
   canData[7] = 0x00;
   //switch to lower power when reaching target temperature
   if (currentTemperature < targetTemperature - 10) {
    canData[2] = 0xA2;
    power = 2;
   } else {
    canData[2] = 0x32;
    power = 1;
    CAN.sendMsgBuf(0x188, 0, sizeof(canData), canData);
  } else {
    power = 0;
void ms1000Task() {
  Serial.println("Heater Status");
  Serial.print("HV Present: ");
  Serial.print(hvPresent);
  Serial.print(" Heater Active: ");
  Serial.print(heating);
  Serial.print(" Water Temperature: ");
  Serial.print(currentTemperature);
  Serial.println("C");
  Serial.println("");
  Serial.println("Settings");
  Serial.print(" Heating: ");
  Serial.print(enabled);
  Serial.print(" Desired Water Temperature: ");
  Serial.print(targetTemperature);
  Serial.print(" Inverter: ");
  Serial.print(inverterStatus);
  Serial.println("");
  Serial.println("");
void loop() {
  runner.execute();
  //if(CAN_MSGAVAIL == CAN.checkReceive())            // check if data coming
       //CAN.readMsgBuf(&canId, &len, buf);    // read data,  len: data length, buf: data buf
       //if (canId == 0x398) {
if(!digitalRead(CAN_INT))                         // If CAN_INT pin is low, read receive buffer
    CAN.readMsgBuf(&canId, &len, buf);      // Read data: len = data length, buf = data byte(s)
    if((canId & 0x80000000) == 0x80000000)     // Determine if ID is standard (11 bits) or extended (29 bits)
      sprintf(msgString, "Extended ID: 0x%.8lX  DLC: %1d  Data:", (canId & 0x1FFFFFFF), len);
    else
      sprintf(msgString, "Standard ID: 0x%.3lX       DLC: %1d  Data:", canId, len);
    //Serial.print(msgString);
    if((canId & 0x40000000) == 0x40000000){    // Determine if message is a remote request frame.
      sprintf(msgString, " REMOTE REQUEST FRAME");
    } else {
      for(byte i = 0; i<len; i++){
        sprintf(msgString, " 0x%.2X", buf[i]);
 //       unsigned int canId = CAN.getCanId();
          //Heater status
          if (buf[5] == 0x00) {
            heating = false;
            power = 0;
          } else if (buf[5] > 0) {
            heating = true;
          //hv status
          if (buf[6] == 0x09) {
            hvPresent = false;
          } else if (buf[6] == 0x00) {
            hvPresent = true;
          //temperatures
          unsigned int temp1 = buf[3] - 40;
          unsigned int temp2 = buf[4] - 40;
          if (temp2 > temp1) {
            currentTemperature = temp2;
          } else {
            currentTemperature = temp1;
          temperatureLastRec = millis();
        if (canId == 0x02) {
          inverterLastRec = millis();
          inverterStatus = buf[0];
        #endif
//      if(inverterLastRec + 500 < millis()) {
//        inverterStatus = 0;
    #endif
Apologies for the untidyness - im learning!
Turbopete
Post by Turbopete »
Is it worth adding a timer to allow the heater coolant pump to run for a couple of minutes after the heater has been turned off? Or is the heater unit robust enough not to worry about?
Turbopete wrote: Tue Dec 27, 2022 8:11 pm Is it worth adding a timer to allow the heater coolant pump to run for a couple of minutes after the heater has been turned off? Or is the heater unit robust enough not to worry about?
I simply switched ON the pump with car starting so coolant will flow regardless.
