Bench setup for stm32-sine development
- catphish
- Has thanked: 94 times
- Been thanked: 179 times
I am currently sourcing parts to build a bench testing setup for stm32-sine (particularly the code targeting Tesla drive units). This is probably one of the least exciting hardware projects on this forum, but I thought I'd document it anyway.
The plan is to build a 1kW openinverter setup in my small home workshop, and use it to test changes to the stm32-sine code. I want to be able to validate openinverter releases before running them in my main vehicle, but also develop some changes of my own.
I've ordered some hardware and will start building once everything arrives:
* 16S (60V) 30AH lithium battery module
* Prius gen2 inverter (and of course the appropriate openinverter logic board)
* 1.1kW 230V 4 pole industrial motor
* 100 PPR optical encoder
- Has thanked: 102 times
- Been thanked: 348 times
Re: Bench setup for stm32-sine development
Nice!
Any plans to add a second motor to provide load/regen capabilities? What are you doing for the encoder/resolver?
Edit - are you planning to use the Prius boost converter to step the voltage up?
- catphish
I haven't worked that out yet. I'm hoping I might be able to use a flywheel to simulate a load for both acceleration and regen.
I will use one of these: https://www.ebay.co.uk/itm/184451719957
It will be belt driven and if possible, I will set up the gearing to provide a reduction to cause it to output around 100 pulses per recolution.
Yes, I'm hoping to run the 1100W 240VAC motor using a 60V battery. Hopefully this is within the capability of the converter.
A flywheel should work, it's essentially what I do in the simulator using the car mass/inertia.
I'm a little worried how big it might need to be (I have a 2.2kW motor on my lathe and it can easily spin up a 20kg chuck, plus all the gearbox and motor inertia in well under a second). It's also a bit scary how much energy is stored - make sure it's well bolted on and that you don't get tangled up in it, I'd be building a safety cage around it!
Assume it will be a toothed belt to ensure that there is no encoder position drift with time?
- mjc506
- Has thanked: 30 times
- Been thanked: 28 times
If you can get hold of an rowing machine, you may be able to hook up to the fan/impeller to give you a decent load. Flywheels are scary...
- Has thanked: 80 times
- Been thanked: 239 times
I too think flywheel setup is a hazard when spinning. And at its speed it does not want to conform to changes well. You may be exerting a different effect from what you desire. You may be in danger of building weak supports...etc.
Instead of a flywheel you could take a simple drumm brake and use it... as a brake. You can then use its parking brake lever to vary force mechanicaly. Parts are available you would just need to asseemble your setup.
But I would suggest building a simple 2 motor drive setup, ether belt drive or lovejoy coupler whatever sutis best to your setup.
Then you can use your ACIM motor to develop STM32 drive. On the other side put the PMSM motor and wire it to a 3phase diode bridge. Magnets will allways fight movement unlike ACIM. No need for a complex inverter. You make DC after the bridge and put a load on it. Maybe 800W heater or another battery.
Or perhaps the same battery that you use for driving and you can measure output curent vs input current and calculate efficiency of your setup .
- catphish
Unfortunately, one of the main reasons I want a flywheel is to be able to test regenerative braking as well as loaded acceleration. If I were going to use a dual motor setup, then the second motor would need to be powered, not just a load.
I definitely agree that safety is a concern, but hopefully I can build something secure. I don't know how much mass I'll need to achieve a useful result.
- catphish
Yep, at 1kW I guess I'll be building up a decent amount of energy! I think the safest thing will be if I can direct mount a small flywheel onto the motor shaft, but will have to give some thought to securing the overall setup.Pete9008 wrote: ↑Thu Dec 08, 2022 5:32 pm A flywheel should work, it's essentially what I do in the simulator using the car mass/inertia.
Yes, I will 3D print some toothed pulleys and use a toothed rubber belt to drive the encoder and a fixed reduction. I did this successfully once before.
Like the pulley set up, that should work well
The flywheel size needed shouldn't be too dificult to work out, have a look here for the equations https://www.roymech.co.uk/Useful_Ta ... heels.html
Seriously though don't take risks with it. My lathe is properly bolted together but I still don't like standing next to it when it is turning quickly with the big chuck on it!
Edit - fixed link!
Edit - fixed link!
- catphish
This is the kind of setup I was imagining. The flywheel doesn't need to be huge, just enough to provide a meaningful difference between natural spindown, and regen braking.
Like the idea of a flywheel at each end, halves the size and stresses of/on each. Can your motor be used like that?
- catphish
Unfortunately no. Like most industrial motors, the shaft at one end end of mine has a fan bonded to it, and is then covered with a grille. If you want to use both ends, you have to buy a special dual shaft motor that have a longer shaft so that the rear end of the shaft protrudes out beyond the fan and grille.
Hopefully I can make do with one flywheel. If I'm lucky, I can buy a purpose built flywheel with a keyed 12mm hole in the center. I'm not sure if that exists or not tough!
No idea where to get flywheels suitable for fitting to a motor? Taper lock coupler and a small motorbike/mower flywheel machined to fit?
- catphish
Yeah I think an automotive flywheel and an appropriate coupler / hub is much more likely to be feasible. I really lack the engineering background to know where to begin with it!
No! If you simply connect a PMSM motor to your ACIM shaft directly you can then load its 3phase ooutputs via diode bridge to a heater element.catphish wrote: ↑Fri Dec 09, 2022 8:37 pm Unfortunately, one of the main reasons I want a flywheel is to be able to test regenerative braking as well as loaded acceleration. If I were going to use a dual motor setup, then the second motor would need to be powered, not just a load.
If you want to release it you just disconnect the load and it will spin unloaded. No need to power the PMSM. You simply provide a suitable load.
I'd work out what kind of size you need first then look for what's available. May be that you can manage with something fairly small (say a go cart wheel that might be easier to mount?).
My (very limited) engineering experience is telling me that I probably wouldn't want to stand next to it though
12mm sounds very small for a 1kW motor, are you sure it's not larger?
- catphish
Can't argue with that! The diameter before the turned down section is more what I'm used to seeing.
Not sure I'd be happy putting anything more than a fairly small, well balanced flywheel on that though. I could see the vibration from any out of balance causing fatigue problems after a while.
Edit - wondering if that motor is designed to go into a gearbox which would limit the side loads/stress on the output shaft.
- catphish
That's a good point. It would definitely need to be well balanced to be secure. The alternatives are quite a bit more complicated though!Pete9008 wrote: ↑Fri Dec 09, 2022 9:48 pm Can't argue with that! The diameter before the turned down section is more what I'm used to seeing.
Must admit to be a bit uneasy about hanging a flywheel on that shaft. Any chance of removing the fan and mounting it on the other end which is probably larger? The way you will be using I can't see cooling will be an issue.
Or reconsider the dual motor approach. An AC motor one side and a PM the other would allow testing of both sine and foc builds!
- mjc506
Running the flywheel off a couple of pulleys would reduce vibration on the motor shaft (may need to deal with side load from the belt) and would allow you to 'gear up' the flywheel to get away with a smaller mass. I'm not sure if a small flyheel turning fast is better or worse than a large flywheel turning slowly though! A small flywheel would be easier to 'contain' inside a cage though.
I have seen twizzy motor variant push out 38kW on a 16mm splined shaft. It was designed for 18kW. As a matter of fact that car is still on the road.
This http://robots.wa4dsy.net/ring-flywheel-calc might be useful. Looks like a modestly sized flywheel can store enough power to be worthwhile. The G calculation is a bit scary though, shows how critical balancing is!
Not worried about torque loads, it should be fine for that. It is more the side loads and vibrational loads that a flywheel could put into it that concern me.
