I bought a Chevy Volt Gen1 DC-DC Converter - Now What? Topic is solved
- mjc506
- Has thanked: 30 times
- Been thanked: 28 times
Re: I bought a Chevy Volt Gen1 DC-DC Converter - Now What?
Ahhh bugger. Amazon? Or get hold of an Arduino Due?
- Gregski
- Has thanked: 355 times
- Been thanked: 474 times
yup, I got an Arduino Due and SaavyCAN works fine on that, I am trying to get it working on Teensy to show folks how it works on there type of thing, plus I like pain
- mjc506
Ah, good to have a working system to compare against
Just a thought, have you got Teensyduino installed? (The Arduino IDE that's been "teensyfied")
- Gregski
this is actually worthy of a discussion or comment, I feel like to really make it headache free you need a dedicated computer or laptop just to a platform because all these microcontroller boards and Arduino sketches totally conflict with one another, I am constantly pulling this library out and putting this one in when going between Damien Maguire's Lexus GS450h VCU (which I luv by the way) and my UNO to talk to my ISA current shunt, to the DUE for CAN Busing and the Teensy for SimpBMSing, anyone else experienced this? I think I saw Damien with multiple laptops in a couple of his videos.
yes and got it working with Tom de Bree's SimpBMS
- Has thanked: 80 times
- Been thanked: 239 times
DOH! I will have to learn all the new systems now!!!
- mjc506
Things do seem to be more stable on Linux, but that's another thing to learn, so... I would have expected everything to play nicely though, just have to change the 'board' each time you swap projects. But yes, library conflicts can be a pain. Although, once you've got each board programmed, they should just talk over serial (ie, you don't need to even have the Arduino IDE open to use Savvycan, and Arduino set to compile for a Due will happily talk to an Uno over the serial monitor for example. Or you could even use another Serial terminal. Apologies if I'm teaching you to suck eggs...
- Gregski
so I've been beating up on the Chevy Volt first gen DC-DC converter in a companion thread called: I think I CAN, I think I CAN... but I want to share some highlights in here as well from what I learned
first here is how to check the polarity ie figure out which wire is positive which one is negative
no light so polarity is correct
- Gregski
and here is something I learned, GM crossed the wires in the intermediate cable running from the converter to the battery pack
- Gregski
here's a close up
- Roadstercycle
- Has thanked: 3 times
Hi Guys,
Been a bit since I've been here. I've been using the Chevy volt Gen 1 DC-DC converter on 3 of my builds. I use a Teensey and 1 line of code to run them. Very simple. Here's the code. I believe I set it to 14.0 volts. I'm on vacation so I can't verify at the moment. The charger is hooked up all the time with no relay, I just turn power on to the teensey and the DC-DC with ignition or when the J1772 is plugged in to run water pump and cooling fan.
Happy Charging!
#include <FlexCAN_T4.h>
const int ledPin = 13;
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can1;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
Can1.begin();
Can1.setBaudRate(500*1000);
void loop() {
Can1.events();
static uint32_t t = millis();
if ( millis() -t > 4 ) {
CAN_message_t frame;
frame.id = 0x1D4;
frame.len = 2;
frame.buf[0] = 0xA0;
frame.buf[1] = 0xB1;
Can1.write(frame);
t = millis(); // reset 5 second counter
Serial.print("CAN1 ");
Serial.print(" ID: 0x");
digitalWrite(ledPin, !digitalRead(ledPin));
Happy Charging!
void setup() {
Serial.begin(9600);
Can1.begin();
void loop() {
Can1.events();
frame.id = 0x1D4;
frame.len = 2;
Can1.write(frame);
- Gregski
well it's been forever and a day since I played with this stuff, but I am finally ready to hook up the DC DC converter on my truck and was wondering if anyone has gotten it to work with a Teensy in a real world example, and since so much time has passed did they ever come out with a Teensy with a built in CAN Bus transceiver on it for compactability
and I know I have been out of the Teesnyduino game for a minute, but tell me this is wrong and they just forgot a decimal
