Hi, I want to add the front parking sensors on my BMW i3. Does anyone know the pinout of the PDC module?
I already have the colors code of the wires and sensors, just need to know the pinout numbers of the module.
BMW i3 PDC module pinout
Re: BMW i3 PDC module pinout
Hi Cloudy, thanks for the answer
Do you know if it is this pinout sequence?
Thank you
Thank you
not sure sorry - you should be able to trace the ground easily to confirm pin 10. Canbus will probably be twisted together (pin 6/15) so that might help also...
- Has thanked: 44 times
If you have the loom half of the plug pull it apart, it'd almost guarantee it was numbered somewhere on the plug, usually really small though
