Failing to precharge
My dumb arse can’t figure out why...
I was able to successfully precharge twice, I then made a HV box with much thicker wires. And the first time I tried to precharge it blew up the resistor I had been using.
I then used a kettle and it still fails to close the main contactor. (But it boiled the water so it was working)
It just opens the precharge one after 5 seconds.
I’m using a Vauxhall ampere battery, at 362v at the moment.
And a Tesla SDU.
My parameters are in the screenshots I couldn’t get them off the inverter on my phone.
The error code is 500 Precharge stopped.
And a Tesla SDU.
- Has thanked: 80 times
- Been thanked: 239 times
Re: Failing to precharge
Do you have a DCDC converter or similar load connected AFTER precharge/contactor? In that case DCDC would pull current through resistor and voltage would never reach DCSW parameter. If you have Ampera battery you may want to use its precharge resistor and additional contactor for DCDC .
Or like me, connect it directly to DC link via a 30A fuse. BUT then in the case of servicing HV you need to either disconnect battery in the middle or pull DCDCs HV connector - for safety.
Hey arber! Thank you! That makes sense!arber333 wrote: ↑Sat Jan 01, 2022 2:53 pm
There isn’t anything attached on the other side, I’m just testing it right now. So negative is directly from battery to motor, positive is through a contractor and precharge.
I am using a 20ohm kettle element, so would have thought it would reach udcsw (which I’m assuming is the same thing as DCSW?)
You have however given me the idea to monitor the voltage across there to see if it reaches it.
I’ll put my brave pants on and go and investigate!
I’m not keen to lower the udcsw value too far but I guess that would be a workaround temporarily?
- Peter
- Been thanked: 8 times
Does the SDU have reverse polarity protection, i.e. a diode ? Could you have the wiring reversed to SDU after your HV box build ?
I’m not sure if it does but I know for certain it’s not reversed, I checked it 100 times before connecting.
I literally have the money for this once... if I mess anything g up I’m finished (
Which is why I’m so anxious over doing it right!
I was using really tiny gauge wire to test before and I think that was adding resistance and protecting the resistor last time.
- Has thanked: 164 times
- Been thanked: 1062 times
In fact every half bridge shorts out when connected in reverse because of the freewheeling diodes that are in it. It much sounds like you are precharging into a dead short, be it reverse polarity or something else.
- Peter
Isolate the HV supply, disconnect the HV leads to motor and test resistance across the SDU motor HV input. Note readings with meter leads reversed too. You should see a resistance fall and rise due to the DC bus caps but resistance should settle in time once they are up to meter voltage. I would suggest you use a 12v supply such as car battery as your HV with your kettle element in series and set UDCSW to maybe 10v accordingly before going back to 362v later. Stay safe and put 362v aside until problem solved.
Update!!
I have since put a voltage tester either side of the main contactor, and the voltage doesn’t rise, (the delta stays 360 volts) but the water in the kettle sizzles a little so current is flowing?
So that’s why the precharge fails...
but why is the voltage not rising at all across the main contactor?
This scares me and I don’t want to think of this being the case but I will check that now
Thank you that’s really helpful!Peter wrote: ↑Sat Jan 01, 2022 3:37 pm Isolate the HV supply, disconnect the HV leads to motor and test resistance across the SDU motor HV input. Note readings with meter leads reversed too. You should see a resistance fall and rise due to the DC bus caps but resistance should settle in time once they are up to meter voltage. I would suggest you use a 12v supply such as car battery as your HV with your kettle element in series and set UDCSW to maybe 10v accordingly before going back to 362v later. Stay safe and put 362v aside until problem solved.
It settled at 62.5k ohms.
Starting at 2mega ohms drooped to 1.7 then fell to 62kohms.
And I get different readings in different polarities... so that’s good?
As for the lower battery pack that’s a plan!!!
I didn’t know what voltage to go for though? I read that you can damage it with too lower voltage?
Precharged fine at 12v.... tapped the ‘start’ wire to 12v and the main contractor clicked... is that it? Is it okay? :O ??
Is it just my settings are wrong?
I changed udcnorm to 11 from 360
Udcsw to 10 from 330
Can I test the throttle a little with 12v or is that a bad idea?
- Peter
You are looking for 0 volts across main contactor high current terminals when energised. You may be able to run motor on 12v if it can draw enough current, possibly 5A - 10A with no load on motor.
Yeah I was getting 360v across when like you say I’d want close to 0v.
My car battery should do 10A no problem.
I will try spinning it up gently tomorrow then
And hopefully Johannes will have the answers
Thank you all for your help so far I was feeling pretty shit about it before, but now I’m hopeful!!
- Peter
Set udcnom to 0 and set Boost at 6000 or possibly more as 12v is a low voltage.
I don’t fully understand the function of the parameters. I‘ll do some google tonight and see
- Peter
Setting udcnom to 0 stops the software from altering settings according to what the udcnom voltage is set to and what the battery pack is actually at. Therefore allowing Boost to be what you set manually without being changed by pack voltage. I was concerned because the boostcalc in your data showed 74000 which is too high by far.
Oh wow... that’s a lot...good spot thank you! I guess I’m going to have to really learn what all the parameters do and interact with eachother. Because I totally didn’t see that as an issue.Peter wrote: ↑Sat Jan 01, 2022 6:14 pm Setting udcnom to 0 stops the software from altering settings according to what the udcnom voltage is set to and what the battery pack is actually at. Therefore allowing Boost to be what you set manually without being changed by pack voltage. I was concerned because the boostcalc in your data showed 74000 which is too high by far.
The database isn’t very in depth.
-sigh- it appears you were correct, at least in part.
I had some success with a 12v car battery.
It was able to precharge, and then the main contactor clicked when start ‘button’ / wire was pressed twice.
But it has since stopped working again, and now shows short across the HV + and - . The short may have been present before, as my tester was playing up.
Have you got any ideas where in the inverter to inspect?
I know it’s quite enclosed in there, so I guess not is it a component that can be replaced?
Any help greatly appreciated thank you all for your help thus far!!
