Hi all,
I'm at the stage in my project where I'm going to be working with HV battery pack/harness junction box etc.
Christmas is coming, so if there are any important tools I'm going to need I could use the opportunity to treat myself.
Insulated spanners/screwdrivers?
Special multimeter? (I have a basic one)
Any recomendations?
Dan
Recommended/most used EV conversion Special Tools?
- Has thanked: 455 times
- Been thanked: 1771 times
Re: Recommended/most used EV conversion Special Tools?
The only tool I consider special in my toolset is a high quality crimper (Rennsteig) with inlays for 4-25mm² lugs
https://www.toolteam24.com/de-DE/rennst ... 14451.html
- Has thanked: 145 times
- Been thanked: 369 times
Hydraulic crimper for up to 75mm2 cablejohu wrote: ↑Sat Nov 20, 2021 4:49 pm The only tool I consider special in my toolset is a high quality crimper (Rennsteig) with inlays for 4-25mm² lugs
https://www.ebay.de/itm/392845310294?ha ... Sw6INdz3NL
Handheld battery powered scope
https://www.ebay.de/itm/283277767182?ha ... SwORxb-6W2
Battery internal resistance meter
https://www.ebay.de/itm/384342572053?ha ... SwdmNhH1RR
Lately the best tool i use would be Canalyst II CAN reader
https://www.ebay.de/itm/383762905544?ha ... SwmZJfhQ5b
Not ev specific, but this has proven invaluable in troubleshooting or testing signals.
https://digilent.com/shop/analog-discov ... er-supply/
Thanks all, I'll go and have a look at some scopes and crimpers
- rstevens81
- Has thanked: 29 times
- Been thanked: 114 times
I would go with Arduino due Plus can shield/board for saavycan
(Commercially available as evtv due)
