Jack Bauer wrote: ↑Wed Oct 20, 2021 12:01 pm It's been a bit since I messed about with the lexus stuff but sounds like you are good to go. Data exchange is happening with the inverter. 65v is more then enough to spin up the motors. What is invstat parameter? When you press throttle is potnom and torque registering a change?
Invstat is ON
Potnom and torque are staying at 0
My pot ranges from 420 to 2580 when fully pressed
Potmin 400, potmax 2800
Potmode single, dirnode switch..
