Dammn you make me tempting togo after one my self too....
I probably will because i still am in need of a front wheel drive motor. But i need tobe sure to have enough room for batteries so i better tackle that first...
!!! Otlichna! Horoshaya rabota!
What is a squib?
Shown here - pyro device to blow the busbars in case of a catastrophic fault
Sorry about missing that when I reviewed. That was my design fix too...Jack Bauer wrote: ↑Mon Oct 18, 2021 2:52 pm Bad news : Design flaw! That 1k pull down resistor on ADBUS5? Should have been ACBUS5!! Gahhh. Anyway. Boards are fairly cheap from jlc without the ft2232 so I'll fix and order a fresh batch.
That's only simpler if you can find the mating connector and successfully crimp the pins. Damien's board is a MUCH easier solution for everyone else. Since he's tested it to work (other than the one problem) I'd say he's in good shape and everyone is likely to want to go that route rather than crimping pins you need brain surgeon dexterity for.
