Mounting motor/inverter/PDM separately...
Greenbeast
Post by Greenbeast »
Can someone point me to any projects where the leaf stack components were separated and mounted independently?
Greenbeast
Re: Mounting motor/inverter/PDM separately...
Interested because I'm wondering if I could mount the inverter and charger forward of the motor and leave a nice large, square area for batteries/HVJB above them all
earthman
Post by earthman »
it is dangerous to put batteries in the front, in case of an accident they will be damaged, instead of a gas tank and a silencer. and the center of gravity is lower
celeron55
Has thanked: 28 times
Been thanked: 110 times
Post by celeron55 »
I did that in mine. Note that I did add some cable protector and proper cable mounts and I would recommend a ground sleeve/mesh for the motor phase cables for EMI reasons, it's on my late to-do list. As for the PDM, it has cables already, just cover the extra holes you aren't using.
zippy500
Has thanked: 32 times
Post by zippy500 »
looks really smart, does anyone know how to control the Charger/DcDc unit ?
Greenbeast
earthman wrote: Sat Aug 14, 2021 2:36 pm it is dangerous to put batteries in the front, in case of an accident they will be damaged, instead of a gas tank and a silencer. and the center of gravity is lower
Yes I've read that before, I've also seen plenty of batteries put up front
Greenbeast
celeron55 wrote: Sat Aug 14, 2021 2:46 pm I did that in mine. Note that I did add some cable protector and proper cable mounts and I would recommend a ground sleeve/mesh for the motor phase cables for EMI reasons, it's on my late to-do list. As for the PDM, it has cables already, just cover the extra holes you aren't using.
Nice one, thanks for putting the pictures here for me
Alibro
Has thanked: 271 times
Been thanked: 150 times
Post by Alibro »
Do you already have the motor and inverter?
I need a bigger hammer!
Greenbeast
Alibro wrote: Sun Aug 15, 2021 12:04 pm Do you already have the motor and inverter?
No, I don't
Alibro
Post by Alibro »
If you get the Mk1 Leaf motor and inverter they are already separated. The leads are around 30cm long.
Greenbeast
Ah, thanks!
Alibro
Post by Alibro »
This my the motor removed from the donor Leaf and you can see the Inverter lead on the top.
