Inverter P/N Compatible with V1c Gen 3 board? (G9200-47230)
Hello does anyone know if this 2014 Prius inverter P/N (G9200-47230) compatible with the V1c board it not listed on the WIKI under Toyota part numbers. I believe it is just want to confirm before buying. thanks
Re: Inverter P/N Compatible with V1c Gen 3 board? (G9200-47230)
If I recall correctly, the important numbers are on the control board inside.
I have the same inverter and the v1d small board fits in nicely. Thus, I think that the v1c board is too big.
thanks that's good information what year car is your inverter from?
2015invokeperformance wrote: ↑Wed Jun 30, 2021 6:01 pmthanks that's good information what year car is your inverter from?
- Has thanked: 75 times
- Been thanked: 306 times
Please update the wiki with details
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
I've seen this info in other threads as well. 2010-2011 use the "large" boards, everything Gen 3 after that uses the "small" boards originally for the Auris/Yaris. V1D (I believe) is specifically for dual motor where V1C is for single, and they're both available in small and large designs. Single motor will be a bit cheaper.
FWIW, the small board inverters seems a hair cheaper to buy used.
Patreon supporter and mild troublemaker. You can be both.
