I'll be sure to let you know if I ever make progress on that front... there's quite a bit to do on the rest of the vehicle.Boxster EV wrote: ↑Wed Mar 17, 2021 12:37 pm Really interested to hear how you get on mounting the ibooster. I'm keen to go that direction too but haven't really assessed how well it'll physically fit in the frunk.
I have two annoying things on my 986. One is the power steering pump noise and the other is the vacuum pump kicking in. Hoping to improve both this summer.
Agreed, vacuum pumps sound disgusting; I've got a RAV4 EV on hand at the moment and even Toyota couldn't make it quiet. Though the power steering (Astra pump methinks) sounds pretty cool...
2 week update time. My dad and I spent the last week building mounts; front, rear, and side.
Here they are installed on the motor: And then today we lifted it into the car. After an hour or so of shoving it around and forcing bolts, it's finally mounted in place permanently (I hope). Axles are bolted up and fitting properly, HV wiring is complete, and the LV wiring is easily completed. But the batteries need some support, a chassis part needs to be replicated (interfered with motor), and coolant hoses connected. After that is done, we'll be on the road again.
Things are moving along though! It's getting exciting!
-Isaac
