Isaac96 wrote: ↑Sun May 24, 2020 8:20 pm
I was controlling my tachometer with Arduino using the tone() command. This just outputs a square wave with a given frequency. (I later broke the tachometer by feeding it power instead of using open collector... oof)
https://www.arduino.cc/reference/en/lan ... d-io/tone/
See what the tachometer does with a 200hz signal maybe?
Looks like the 406 is a 4 cyl engine, so 200hz should be 3000 rpm???
-Isaac
Nope! My 406 coupe was made by Pininfarina in Turin. Actually it had V6 3L engine. And to complicate matters further tacho uses 60 hole ring on torque converter with last two holes lengthened. In effect last three pulses are one pulse that lasts 3 periods. I dont think just tone generator would suffice.
Lo and behold! I was playing with Arduino code and copiyng Damiens code into Rons and suddenly i got square pulse out of D10. Since it was 0V to 5V it obviously didnt do anything for my RPM which needs a "zero crossing" to count one pulse. Since last time Ron suggested to use a ceramic cap to invert falling side of pulse below 0V i tried that. Wow! I instantly got a series of relays clicking and my RPM indicator rose to 450RPM!!!!
Now second iteration i setup to 850rpm to look more natural to driver. Surprisingly i even got ABS system working with one wheel up!
Now i just have to discover if i can use signal from D2 to vary the D10 with 58 pulses per rotation.
See the code i mashed up:
* © 2019 Ron Simpkin
* Public domain - do with it what you will
* Works on Arduino Uno and Pro-mini and probably any other 328p based Arduino running at 16MHz
* Limitations:
* lowest output frequency available is > 0.0595Hz
* highest output frequency is 4MHz -> but very poor resolution up this high (next highest is 2MHz)
* Digital Pins are _fixed_
* Digital pin 2 for incoming pulses
* Digital pin 9 for outgoing pulses
* Default pin for analog in is A2
* Un-comment ONE define to set the mode
* 1. MODE_FIXED:
* outputs a fixed frequency = RPM * PULSES_PER_REVOLUTION / 60
* change the #defines to suit your needs - all values must be postfixed UL
* 2. MODE_ANALOG_IN:
* outputs a frequency with a settable minimum and maximum depending on
* the voltage on an analog pin (default pin A2)
* 3. MODE_PULSE_IN
* takes an input signal on pin 2 and outputs a signal on pin 9
* set SOURCE_PULSES equal to the number of pulses in per revolution
* set PULSES_PER_REVOLUTION equal to the number of pulses you need to go out each full revolution
* set RPM_CUTOFF to the minimum RPM input you want to map directly to output pulses
* when the input drops below RPM_CUTOFF then the output is RPM_MIN
* NB. SOURCE_PULSES can't be set to 1. If it is actually 1 set it to 2 and double the other settings.
//#define MODE_FIXED
//#define MODE_ANALOG_IN
#define MODE_PULSE_IN
const int pulseInPin = 2;
const int pulseOutPin = 9;
const int analogInPin = A2;
float fTarget, fMinimum, lastTarget;
#ifdef MODE_FIXED
#define PULSES_PER_REVOLUTION 1
#define RPM 2000UL
#endif
#ifdef MODE_ANALOG_IN
#define PULSES_PER_REVOLUTION 8
#define RPM_MIN 40
#define RPM_MAX 800UL
unsigned long analogValue;
unsigned long lastValue;
#endif
#ifdef MODE_PULSE_IN
#define SOURCE_PULSES 2
#define PULSES_PER_REVOLUTION 10
#define RPM_CUTOFF 2UL
#define RPM_MIN 0
#define PULSE_PIN 10
volatile float time = 0;
volatile float time_last = 0;
volatile int rpm_array[5] = {0,0,0,0,0};
int rpm = 0;
float val = 0;
volatile int pulIn = 0;
volatile int lastPul = 0;
volatile unsigned long now;
volatile unsigned long startMicros[SOURCE_PULSES];
volatile unsigned long lastPulMicros = 0;
volatile float fIn = 0;
volatile int suppressStart = 0;
float fCutoff;
#endif
void setup()
pinMode(pulseOutPin, OUTPUT); // set pin 9 as output - it's this pin that get togged by PWM
pinMode(PULSE_PIN, OUTPUT);
//Digital Pin 2 Set As An Interrupt
attachInterrupt(0, tach_interrupt, RISING);
noInterrupts();
// Configure timer 1 (16bit resolution)
TCCR1A = 0;
TCCR1B = 0;
OCR1A = 0;
// Select Phase & Frequency Correct PWM Mode, and OCR1A as TOP.
// Enable COM1A0 to toggle OC1A on compare match (pin 9)
TCCR1A |= ((1 << WGM10) | (1 << COM1A0));
#ifdef MODE_FIXED
fTarget = (float) RPM * PULSES_PER_REVOLUTION / 60;
setPWM(fTarget, fTarget);
#endif
#ifdef RPM_MIN
fMinimum = (float) RPM_MIN * PULSES_PER_REVOLUTION / 60;
#endif
fCutoff = (float)RPM_CUTOFF * PULSES_PER_REVOLUTION/ 60;
for (int i=0; i < SOURCE_PULSES; i++){
startMicros
= 0;
pinMode(pulseInPin, INPUT_PULLUP);
// use interrupt 0 (pin 2) and run function countPulse when pin 2 goes HIGH
attachInterrupt(digitalPinToInterrupt(pulseInPin), countPulseIn, RISING);
#endif
interrupts();
void loop(){
int pinVal = analogRead(analogInPin);
analogValue = map(pinVal, 0, 1023, RPM_MIN, RPM_MAX);
fTarget = (float) analogValue * PULSES_PER_REVOLUTION / 60;
if (lastValue != analogValue){
setPWM(fTarget, max(fTarget, fMinimum));
lastValue = analogValue;
#else if MODE_PULSE_IN
float f = fIn;
fTarget = f * PULSES_PER_REVOLUTION;
if (fTarget < fCutoff){
fTarget = fMinimum;
if (micros() - lastPulMicros > 1000000UL){
fTarget = fMinimum;
if (lastTarget != fTarget){
lastTarget = fTarget;
if (suppressStart == SOURCE_PULSES){
if(time > 0)
//5 Sample Moving Average To Smooth Out The Data
rpm_array[0] = rpm_array[1];
rpm_array[1] = rpm_array[2];
rpm_array[2] = rpm_array[3];
rpm_array[3] = rpm_array[4];
rpm_array[4] = 60*(1000000/(time*2));
//Last 5 Average RPM Counts Eqauls....
rpm = (rpm_array[0] + rpm_array[1] + rpm_array[2] + rpm_array[3] + rpm_array[4]) / 5;
//val = rpm;
//val = 517; //1000rpm 517uS , 250rpm = 2068uS , 4000rpm = 129uS
rpm = constrain(rpm, 850, 7000);
//Serial.println(rpm);
val = ((rpm/60)*58);
val = 1/val;
val = val/2;
val = val*1000000;
//Serial.println(val);
//val = map(val, 250, 4000, 2068, 129);
for(int i = 0; i < 58; i++) {
triggerHigh(val);
triggerReference(val);
#endif
Simulate the high of a tooth on a
reluctor wheel
void triggerHigh(unsigned long val) {
digitalWrite(PULSE_PIN, HIGH);
delayMicroseconds(val);
digitalWrite(PULSE_PIN, LOW);
void tach_interrupt()
time = (micros() - time_last);
time_last = micros();
Simulate the reference marker on a
reluctor wheel
void triggerReference(unsigned long val) {
// pin should be low already
delayMicroseconds(val); // two delays for two missing pulses.
void setPWM(float fTgt, float fMin){
float pwmClock;
if (fTgt <= 0.0595){OCR1A = 0;return;}
/* Set all of TCCR1B in one operation - Binary assignment!*/
if (fMin > 61.1 ){
//TCCR1B |= ((1 << CS10) | (1 << WGM13)); // Fcpu/4 61.1Hz -> 4MHz
TCCR1B = B00010001;
pwmClock = 4000000.00;
}else if (fMin > 7.64){
//TCCR1B |= ((1 << CS11) | (1 << WGM13)); // Fcpu/32 7.64Hz-> 500KHz
TCCR1B = B00010010;
pwmClock = 500000.00;
}else if (fMin > 0.952){
//TCCR1B |= ((1 << CS10) | (1 << CS11) | (1 << WGM13)); // Fcpu/256 952mHz->62.5KHz
TCCR1B = B00010011;
pwmClock = 62500.00;
}else if (fMin > 0.239){
//TCCR1B |= ((1 << CS12) | (1 << WGM13)); // Fcpu/1024 239mHz -> 16.25 KHz
TCCR1B = B00010100;
pwmClock = 15625.00;
}else{
//TCCR1B |= ((1 << CS10) | (1 << CS12) | (1 << WGM13)); // Fcpu/4096 59.5mHz -> 3.9 KHz
TCCR1B = B00010101;
pwmClock = 3906.25;
OCR1A = round(pwmClock/fTgt);
void countPulseIn() {
lastPul = pulIn;
now = micros();
if (pulIn < SOURCE_PULSES -1){
pulIn++;
}else{
pulIn = 0;
if (suppressStart > SOURCE_PULSES -1){
fIn = (float)1000000/(now - startMicros[pulIn]);
}else{
suppressStart++;
lastPulMicros = now;
startMicros[pulIn] = now;
#endif
