Toyota Auris and Yaris Inverter Logic board
Been thanked: 87 times
Re: Toyota Auris and Yaris Inverter Logic board
They are just generic parts made by dozens of manufacturers.
bexander
Has thanked: 63 times
Been thanked: 89 times
Post by bexander »
Ok, I'll stop worrying and just buy one.
Thank you!
Anyone experiencing problems running motors in reverse after successful tuning please set fwkp to 0 and try again. Johannes and I are working on this problem. A full tuning and tutorial video can be expected in about a week.
bexander
Post by bexander »
Have the parameters from the FOC tuning video been posted on the forum? I can't find them and I'm very curious on the current gain from the Yaris MG2 outputs used by Damien.
jalovick
Has thanked: 10 times
Been thanked: 6 times
Post by jalovick »
Which Auris/Yaris/Prius-C inverter part numbers has this version of the board been shown to work with?
Thanks!
chrskly
Has thanked: 39 times
Been thanked: 38 times
Post by chrskly »
When it comes to paralleling the inverter MG1 and MG2 outputs is there any particular way those connections should be made?
Create three short cables to link MG1 inverter output to MG2 output. Then link MG2 output to the motor?
Or, two separate runs? One from MG1 inverter output to the motor and another from MG2 inverter output to the motor?
Does it matter?
Bexander, at this point may I ask that you move this to a seperate thread. Please don't missunderstand me its very valuable work that I appreciate but I do want to keep the support threads on topic as much as possible. Thanks:)
Has thanked: 162 times
Been thanked: 1045 times
I have split the topic, it continues here: viewtopic.php?f=7&t=1085
bexander
Post by bexander »
chrskly wrote: Sat Oct 10, 2020 8:43 pm When it comes to paralleling the inverter MG1 and MG2 outputs is there any particular way those connections should be made?
Does it matter?
I have not tried this myself but I would use three short cables to link MG1 out to MG2 out. Then MG2 to motor.
I don't see any advantages using two separate cable runs when only one stator is driven.
chrskly
Post by chrskly »
bexander wrote: Tue Oct 13, 2020 2:59 pm
Does it matter?
Cool, thanks. I’m mostly just making sure I’m not doing something nuts and that this is what people mean when they say paralleling the outputs.
NiHaoMike
Post by NiHaoMike »
When paralleling transistors, it's often a good idea to have resistors to ensure current sharing. Run two sets of wires about the same length for the MG1 and MG2 outputs, but MG2 should use wire with about twice the copper cross section as MG1 since MG2 is rated for more current.
TheSilverBuick
Post by TheSilverBuick »
Made it across the pond and plains all in one piece. Thanks Damien. I've been futzing with the gas engine in my Firebird, I need to get back to this project!
Leo M
Post by Leo M »
din-ocur Error. What is this error ? Tell me who any please....
Martin1775
Post by Martin1775 »
The din_ocur is in error status because in the design of the board, input PA1 is not connected, it should have no effect to the function.
Leo M
Post by Leo M »
Thanks. I thought so...
canuck
Post by canuck »
Hey folks, I am setting up the following:
Inverter: Toyota Auris/Yaris Inverter
Motor: EM61
Resolver
Board: Auris/Yaris/CT200H Inverter Logic Board V2 Block II
Firmware: v4.97.R
I am getting an angle plot that looks like:
It responds generally close to the expected trend, however when I quit turning the motor shaft it has a large jitter value (15 - 100 degrees) on the angle it rests at.
I believe this is a resolver wiring job issue on my end. I have been trying all sorts of wire combinations (in the manner Damien suggested in his FOC Tuning Video) but can't seem to rid myself of this 15 - 100 degree buzz. Has anyone experienced this before?
I have identified my resolver wiring pairs (excitation pair and my sin/cos pairs) properly. However, I think my error may lie in my sin/cos pairs to PCB connection:
Resolver Wire J1 PCB Pin
Excitor 1 ----> 21 (MG2_EXCA)
Excitor 2 ----> 22 (GND)
Sin 1 ----> 16 (MG2_ENC_1)
Sin 2 ----> 18 (GND)
Cos 1 ----> 17 (MG2_ENC_2)
Cos 2 ----> 18 (GND)
I have also tried having my common pair (Sin2 and Cos 2) tied to PCB Pin 15 (VCC_5V), as this looks to be how Brain Board Rev 3.4 does it.
Where should the common pair pins be tied for correct Auris/Yaris operation?
I'm going to continue digging around the forum to see what I can find! :)
bexander
Post by bexander »
canuck wrote: Thu Jan 14, 2021 8:43 pm Resolver Wire J1 PCB Pin
Try and move the sin and cos from GND to MG2_SINA and MG2_COSA.
Sin 2 ----> 18 (MG2_SINA)
Cos 2 ----> 18 (MG2_COSA)
canuck
Post by canuck »
bexander wrote: Fri Jan 15, 2021 3:43 pm Try and move the sin and cos from GND to MG2_SINA and MG2_COSA.
Thanks for the suggestion bexander. However even after moving my sin and cos from GND to MG2_SINA and MG2_COSA I am still experiencing a rather nasty (and relatively constant) amount of jitter/noise (around 50 to 100 degrees worth).
(I have updated my naming conventions to match information I dug up in the forum yesterday)
For clarity, my connections are as follows:
cos+ (S2) ---> MG2_ENC_1
cos- (S4) ---> COSA
sin+ (S1) ---> SINA
sin- (S3) ---> MG2_ENC_2
Also, I monkeyed around with these four feedback sin/cos connections and my jitter remains active in all 4 sin/cos configurations.
After investigating with my scope, the excitation and feedback signals look like:
EXCA = 12V (peak to peak) sinusoid [this could be a bit high, as Johannes has mentioned that we're looking for a 7V-9V amplitude]
MG2_ENC_1 = 1V-3V (peak to peak) sinusoid, varies when I manually turn the motor
MG2_ENC_2 = 1V-3V (peak to peak) sinusoid, varies when I manually turn the motor
(feed)
I also have access to a Gen 3 V1C Block III board, and I am seeing the same behavior. This makes me think that I may have an issue with my setup.
That is some truly heavy jitter. I'm assuming you're not running the inverter yet, just turning by hand? How about shielding and grounding of shield? Can you send a picture of your setup?
On the Yaris boards when using resolver you would need to remove the two pullups R30 and R29. See schematic :
https://raw.githubusercontent.com/damie ... ematic.pdf
canuck
Post by canuck »
Thanks for the input guys! I now have a functional Auris V2 Block II Inverter.
The old 'take everything apart and put it back together' trick came through for me. I had pulled R29 and R30 prior to my original post as I had found Damien's original heads up in another forum, but I can see that being an easy thing to miss! I think my problem must have been a bad connection somewhere in my system. I kept bexander's advice with the sin and cos connections to MG2_SINA and MG2_COSA when I rebuilt my setup. Thanks bexander!
Here is my new angle plot (via hand-crank):
Here is my new reduced jitter plot:
And here is my physical setup:
I appreciate the help! Looking forward to being in a position to give back and assist others on here.
thornogson
Post by thornogson »
In an attempt to give back what I can to this community, I had a stab at bringing together what we know about the Auris/Yaris inverter on a wiki page here :
https://openinverter.org/wiki/Auris/Yaris_Inverter:
Please check it over for inaccuracies and amend/update accordingly
thanks, John
thornogson
Yaris/Auris block 111 board,imiev motor supposed good, same results on mgr bench pig Help please , having failed to find anything on the angle plot, I went back to see what the resolver is being fed, this is the exciter output to the resolver nothing else except wifi connected, latest FOC software, inverter running doesn’t look right to me where to look for possible problems?
konstantin8818
Post by konstantin8818 »
So... Block IV arrived :)
And my first question: to make it work with resolver I need to remove R39 and R38? As I remember correct, Damien you said you'll make a jumper for switching between encoder/resolver?
PDF schematics here :
https://github.com/damienmaguire/Yaris- ... are/Block4
I may have forgotten the jumpers....sorry ....
