1014963-05-B doesn't work yet. Has a different voltage to data offset, and definitely appears to have some comms incompatibilities.
1014963-00-L works fine.
I can confirm that all PCB's are identical between units.
I put the original "Elon" boards back on them to pull the comms. Didn't see anything particularly helpful in them, but I figure I'll drop those here for future reference if anyone wants that info. board turned on, DC switched on later (377v), then DC off, then the log ends. There is an extra couple of ID's on the 05-B log.
Also, I individually pulled logs from each module to be able to confirm which unit sends what, updated the DBC file to have all the comms from the individual phases at least marked as "Module 1" or 2... (again, extention changed to txt so it would allow me to attach it. change it to .DBC to use it)
I actually uploaded GVRET to the V4 charger board, and added 3 lines to the void Loop(),
digitalWrite(3, HIGH); //enable phase 1 power module
digitalWrite(4, HIGH); //enable phase 2 power module
digitalWrite(5, HIGH); //enable phase 3 power module
Anyway,
I am happy and relieved that I finally can charge my battery!
