Hi Guys
I recently became the owner of an almost complete Gen 1 Nissan Leaf so after a few days stripping I have the motor and inverter along with many other bits on the bench. I also have a Gen 2 Toyota Prius inverter so I now have to decide which route to take, i.e. stick with the Leaf hardware and use the EVBMW controller board or use the Leaf motor and the Prius inverter with Johu's controller.
My original plan was to buy a Gen 2 Leaf and use Johu's controller board but the Gen 1 Leaf came along at a great price and I couldn't refuse.
I was about to launch into a question about which board should I go for then thought, Sod it and ordered Damiens board.
The Leaf inverter was designed to drive the Leaf motor so they should in theory be a better match than the LEaf motor with a Prius inverter.
I can always buy Johu's board later if I decide to go that way.
Just out of interest I thought I'd post this anyway to gauge other folks reactions. What would you have done?
EVBMW Leaf Gen 1 inverter board or Prius Gen 2 Inverter controller board
- Has thanked: 157 times
- Been thanked: 1025 times
Re: EVBMW Leaf Gen 1 inverter board or Prius Gen 2 Inverter controller board
I would have hacked the Gen1 inverter for good with a drop-in board There is a working board out there, but not for sale anywhere.
The Leaf inverter is more capable in current capability and also in PWM frequency. 4.4kHz recommended for the Prius inverter is somewhat noisy. 8.8kHz is barely audible.
- Has thanked: 270 times
- Been thanked: 150 times
LOL, I might have known you would say that. If I could have hacked it I would.johu wrote: ↑Thu Aug 27, 2020 8:03 pm I would have hacked the Gen1 inverter for good with a drop-in board There is a working board out there, but not for sale anywhere.
80Kw is plenty for me (for now) so power is not a consideration. I guess as this is my first conversion simplicity is most important.
I need a bigger hammer!
- Been thanked: 8 times
It might be easier to get approval for the Leaf inverter/motor combination? Not having gone through it yet myself, I don't know if it actually makes a difference, but they have been EMC tested as a system.
