Lotus Excel
- SciroccoEV
- Been thanked: 16 times
Lotus Excel
Delivered today, yet another project. Lots of work needed!
Thinking GS300H gearbox as the 450H is probably too big to fit into the backbone.
Re: Lotus Excel
should be a great build, has some delorian similarities, feel like its calling out for that louvered rear window.
- Has thanked: 479 times
- Been thanked: 314 times
Re: Lotus Excel
Looks a bit like a boxy 928.
Cool. I wanted to convert a Lotus Elise for years. Never knew anything about cars or how much they cost. Dug around and saw an Exige for $16,000 here a few years ago, and figured, okay, I could afford that, I'll wait around and see what the market is like, pick one up cheap.
I've since learned that even a salvage Elise is a bargain at $30,000. Hrmph.
- bobby_come_lately
- Has thanked: 56 times
- Been thanked: 63 times
- SciroccoEV
Re: Lotus Excel
I've been wanting to do a Lotus conversion since the 90's when I was prepping and developing the Porsche 914 race EV in the US each year.
The 1985 Excel is actually lighter than the same year Esprit and has also four seats, rather than two. It's also a lot cheaper, so although I would have liked to do an Esprit, I think the Excel may be a better choice.
I'm now leaning more towards a Leaf motor onto the original gearbox. The Lotus's 4.1 rear diff poses gearing problems compared to the 2.764 of the 300h and drop in alternatives ratios are limited. It's a Toyota Supra derived unit with a uniquely Lotus mounting arrangement.
- bobby_come_lately
Re: Lotus Excel
Probably not the last 'uniquely Lotus' thing you'll have to deal with I suspect. Brilliant project though.SciroccoEV wrote: ↑Sun Aug 16, 2020 3:24 pm I've been wanting to do a Lotus conversion since the 90's when I was prepping and developing the Porsche 914 race EV in the US each year.
Will original gearbox deal with the torque?
- SciroccoEV
Re: Lotus Excel
The Toyota W58 should be fine, even the version with the alloy centre plate gets used in V8 conversions.
- PacEmaker
- Has thanked: 5 times
Re: Lotus Excel
What a great project idea! I'm looking forward to progress reports...
If you put a Leaf motor up front of the original gearbox, will you be able to retain install batteries in a way that allows something like the original weight balance for the Lotus?
Geoff
Is this smoke trying to tell me something ...
- SciroccoEV
- Has thanked: 166 times
- Been thanked: 413 times
Re: Lotus Excel
Really nice conversion.
With a small weight of that car and power/torque of the Leaf motor i think you better install some wings on that car.
I do think the suspension is really good so this will have some great cornering capability.
- SciroccoEV
Re: Lotus Excel
I just had a 22kw BMW i3 pack delivered today. Relatively low capacity, but easy to upgrade to the later higher capacity modules in the future.
Got a deal on ebay, just under £100 per kwh.
- SciroccoEV
- SciroccoEV
Re: Lotus Excel
OK, time for a battery upgrade.
But you haven't started on this one yet!
I know, but I couldn't resist.
18 off CALB modules, 6S1P, ~112Ah, 12.35Kg 355mm long, 152mm wide, 115mm tall.
- ZooKeeper
- Has thanked: 8 times
- Been thanked: 5 times
Re: Lotus Excel
Does that make this a "Lotus Leaf"???
Time for ICE Melt
- SciroccoEV
Re: Lotus Excel
The lotus is second in the queue. My 1984 Scirocco, which I converted 20 years ago, is the priority at the moment.
Re: Lotus Excel
I am after 4 modules of these same batteries. Where did you source yours? Have you got any left from your project?SciroccoEV wrote: ↑Mon Mar 01, 2021 11:40 am OK, time for a battery upgrade.
Cheers
CZ
- SciroccoEV
Re: Lotus Excel
The Excel finally got some attention. It's up on my portable vehicle lift and I've started the suspension/brake rebuild.
Although it's a galvanised chassis, it stood in someone's garden since 2006 and some (unplated) suspension components are beyond use. I had always planned to take the body off the chassis, but many people had tried to discourage me from doing so, "It will be fine, they never rust". Whilst I don't think there are any areas actually rusted through, I've seen enough areas of concern that I am going to split the body and chassis, so that it can be cleaned up at the rust pprotection renewed.
Re: Lotus Excel
I'm sure I was watching youtube last night and saw you on 'the late brake show' & projects of the people???SciroccoEV wrote: ↑Fri Dec 31, 2021 9:29 pm IMG_20211217_103836.jpgThe Excel finally got some attention. It's up on my portable vehicle lift and I've started the suspension/brake rebuild.
- SciroccoEV
Re: Lotus Excel
Aha great, i'll be sure to check out the other episodes...
- SciroccoEV
