Managed to break the current sensor while swapping the board on my small rear drive unit.
Can anyone help me with a replacement current sensor?
Thanks in advance.
Broken current sensor [SOLVED]
- Been thanked: 1918 times
Re: Broken current sensor
I remember Damien found the part number. It is actually just the hall sensor you need to swap, the magnetic core can stay in. I guess you can start to remove the sensor from the core and wait for Damien to post the part number. I can't find it right now even though it should be on the forum somewhere.
- Been thanked: 1139 times
Re: Broken current sensor [SOLVED]
viewtopic.php?f=10&t=77&start=20#p2266
Please post support questions in the relevant support thread.
Thanks Herr Bauer
I closed the support thread because, as we just witnessed, its hard to find info there even for the forum founder
Jack Bauer wrote: ↑Sat Aug 03, 2019 8:00 am The current sensor used on the small drive unit is the Melexis MLX91209.
https://www.mouser.ie/ProductDetail/Mel ... 4jl%2Fc%3D
The 7.3mV/mT version.
The same thing happened tome a few hours ago. Great to see this information
Mr Stinny, did you succeed to change the sensor?
There seems to be two hall sensors, are both needed anyway?
Alfa Romeo 147 with Tesla FDU and Kia soul pack
