Leaf spline coupler
doobedoobedo
Re: Leaf spline coupler
Post by doobedoobedo »
jerrykco wrote: Sun May 10, 2020 1:02 pm
Kevin Sharpe wrote: Sun May 10, 2020 8:38 am
celeron55 wrote: Fri May 08, 2020 4:46 pm The ghetto Leaf coupler is a Blue Print ADC43101 clutch disc or similar. It fits a bunch of japanese and korean vehicles and is cheap.
Damien is using a Fiat Van clutch disc (watch from 2:35) :)
Is this the clutch plate?
Clutch Plate Fiat Ducato 2500 Turbo Diesel MK1 85-93 Clutch Disk?
He mentions it being a Fiat Multipla.
jerrykco
Has thanked: 71 times
Been thanked: 27 times
Post by jerrykco »
Thanks, I couldn't catch that. I listened several times too.
Jerry Kauffman
jerryk48 at gmail dot com
zippy500
Has thanked: 76 times
Post by zippy500 »
Think the Suzuki one fits too,
Think thats what this guy did
Kevin Sharpe
Been thanked: 8 times
Post by Kevin Sharpe »
jerrykco wrote: Sun May 10, 2020 5:49 pm Thanks, I couldn't catch that. I listened several times too.
Yeah, its the Fiat Multipla :)
https://en.wikipedia.org/wiki/Fiat_Multipla
Kevin Sharpe
zippy500 wrote: Sun May 10, 2020 6:09 pm Think the Suzuki one fits too
Many thanks :)
Cookie6000
Has thanked: 12 times
Been thanked: 33 times
Post by Cookie6000 »
Here is how the 1.6l Fiat Multipla centre spline fits the Leaf output shaft
Has thanked: 10 times
Been thanked: 335 times
While I don't have many miles on my Fiat clutch Leaf coupler I do have some experience with these things:)
My opinion is that having a perfect coupler would be perfect having one that works ...well, works. I have seen the most ridiculous couplers last for ages and those machined down to microns come flying out the side of a bellhousing. I've even done both myself. Don't let the pursuit of perfect keep you from getting on with a build.
Has thanked: 134 times
Jack Bauer wrote: Tue May 12, 2020 12:37 pm While I don't have many miles on my Fiat clutch Leaf coupler I do have some experience with these things:)
I think the same. On my Mazda original clutch is rattling like old kettle. So finally i put two clutch center pieces in my coupler. Now i have peace of mind... It still rattles though.
Kevin Sharpe
Jack Bauer wrote: Tue May 12, 2020 12:37 pm Don't let the pursuit of perfect keep you from getting on with a build.
This is a really important point :)
KarmannLeafBlower
Post by KarmannLeafBlower »
Bratitude wrote: Sun May 10, 2020 3:01 am
jerrykco wrote: Wed May 06, 2020 11:35 pm
Bratitude wrote: Wed Mar 25, 2020 4:06 am Coupler and assembly design is now finished.
in a few days I’ll be sending out an order for 10 couplers, hopefully.
As I’m sure for many others here, life is a bit chaotic at the moment. So things are taking longer than usual.
Hey, Bratitude,
Can you publish the finished design pictures?
I need to connect the leaf to a drive shaft.
I'm interested seeing if your design will work for me.
Currently away, but couplers are on order.
Ill try to dig out the specs. Spent a good amount of time setting the coupler up to be fairly universal for most people’s needs
What I currently access to.
was ether a 3in or 2.75 di plate with centring marks that match the rotex gs38 bolt pattern.
couple will nest in an angler bearing, with renting clip. For those wishing to run a clutch or drive shaft.
You have another customer here in the UK! Need your solution to link to a Karmann Ghia gearbox....
Don't believe everything you think.
Has thanked: 168 times
Been thanked: 351 times
Some time later :)
fits like clockwork
mdrobnak
Post by mdrobnak »
Bratitude wrote: Sat Jun 06, 2020 5:10 pm Some time later :)
fits like clockwork
Wait. Are you putting a flywheel and clutch on this? If so...hmmmmmmm...How can I get one of these in the US?
mleebert
Has thanked: 11 times
Post by mleebert »
Looks great!
I'd love to purchase one of these from you. I have a CNC machine so I'm planning on making my own adapter plate and would integrate the same spec'd angular bearing.
Are you in a position to start selling the coupler?
mdrobnak wrote: Sat Jun 06, 2020 5:52 pm
fits like clockwork
designed the coupler to be as universal as possible, so yes with the angular contact bearing you should be able to mount a flywheel.
few more days and I’ll start taking orders
mdrobnak
Post by mdrobnak »
Bratitude wrote: Sun Jun 07, 2020 1:19 am
fits like clockwork
Sorry, my mechanical knowledge is trash. Does that mean it has a contact bearing in it, or a shop should be able to easily put one in? This solves the concern everyone had about putting too much load on the shaft, correct? Because the bearing is supporting it now?
Do you have any firmer prices, or still $200-300 Canadian? I'm interested in one. The LEAF motor is probably the cheapest option out there with good power...
Thanks for doing this, it's awesome.
-Matt
wwojciech
Post by wwojciech »
Hi everyone. This is my first post. I accidentally came across a clutch from suzuki samurai. What do you think about this? 20x20,1x23,1
Multipla has 20x20,2x23,2
[youtube][/youtube]
zippy500
Post by zippy500 »
That and the fiat clutch plate are your only choice unless you can get a custom one make.
Checkout Damien's video on making the coupler
***check first post for update ***
RetroZero
Has thanked: 550 times
Been thanked: 53 times
Post by RetroZero »
Looking great. Very nice piece of machinery.
mleebert
Post by mleebert »
DM sent :)
mdrobnak
Post by mdrobnak »
It looks awesome! However, you can free my spot as I've gone another direction.
-Matt
Phil3D
Post by Phil3D »
Just curious, why did you go with stainless steel?
Phil3D wrote: Wed Aug 12, 2020 5:22 am Just curious, why did you go with stainless steel?
Cost, machineablity, corrosion resistance, strength, welds well too. What 3D hubs had to offer, 304l seamed like a good choice
vwbrady
Has thanked: 5 times
Been thanked: 18 times
Post by vwbrady »
Can you tell us anything more about which GS coupler parts we need? I'm having trouble because there are just so many options and sizes.
as well, KTR told me they are strictly a EU supplier and that i had to go elsewhere for Rotex parts in NA.
thanks!
The marked bolt pattern (should) match a rotex gs38. but it’s really up to you.
I’m not using a rotex in my application. I’ve milled the transmission coupler with a tapperd angled extrusion(which matches the tapper on the leaf coupler) to centre / provide a friction connection. all clamped together with a 6 m8x1.25 bolts.
I can upload all the cad drawings of each part of the assembly when I’m back at my workspace(about a week or so)
