Parameters database down Topic is solved
Has anyone been able to access the parameters database? It returns a blank screen when trying to access it.
- Has thanked: 393 times
- Been thanked: 110 times
Re: Parameters database down
I might be wrong here but I think the prams database is a local thing to you rather than on a server elsewhere. If it's not working, it will be something local to your setup.
I'm wrong.
- Has thanked: 367 times
- Been thanked: 1536 times
No it is server based indeed.
Probably broke it when upgrading to php8. will check
UPDATE: fixed
UPDATE: fixed
