Nissan leaf igbt specs  [SOLVED]
sour lemon 124
Post by sour lemon 124 »
I'm building a electric motorbike and I was wondering if anyone has a picture or has the specs of a single igbt from a nissan leaf inverter.
cheers
Drw91
Re: Nissan leaf igbt specs
Post by Drw91 »
Hi, I've just teared apart my damaged gen.1 Nissan Leaf inverter. Here are some photos with the IGBTs.
Been thanked: 1914 times
Oh wow, those are good pictures. Trying to understand what I'm seeing...
Diodes on the left, IGBTs on the right. 3 per module. Emitter on the middle rail? Collector on the side rails? An extra connection to both collector and emitter for the gate driver and then 4 gate wires? Where is the temperature sensor? Or did the Leaf 1 not have one? I remember there was none on the control board, instead in the capacitor.
Been thanked: 411 times
Those photos reminded me i have some faulty Volt transistors too.
If you observe the first one you see a black smudge in the bottm right corner. I believe this is toasted transistor junction. Desat certainly thinks so.
Transistors are in some sort of clear goo which trapped the burned traces in my case.
Next photo is from another transistor and here it is not so obvious. A black dot... Desat still throws this one out every time.
Has thanked: 246 times
Been thanked: 469 times
*edit* Gen2 leaf inverter igbts are 600v
What amperage?
Drw91
Re: Nissan leaf igbt specs  [SOLVED]
Post by Drw91 »
Bratitude wrote: Thu Feb 18, 2021 10:24 pm *edit* Gen2 leaf inverter igbts are 600v
What amperage?
I think that the gen1 and 2 are almost the same. The hole pack can easily support 1000A RMS current.
You can find a detailed benchmark here: https://www.energy.gov/sites/prod/files ... 2013_o.pdf
