Hello,
I have a Zombiverter VCU and a 3.6kW Leaf PDM that I am using to charge a battery pack. The battery is supposed to be 72kW when fully charged (400V * 180Ah) and 64kW at nominal voltage (355V * 180Ah). However, when charging with the EVSE set to 15A, I noticed that the current drops to around 1.5A once the voltage reaches 355V and does not increase beyond that. Could you help me understand what might be causing this issue? I have attached a copy of my parameters for your reference.
Zombiverter VCU Charging Cut-Off Guidance Topic is solved
- my_params.json
- (2.13 KiB) Downloaded 489 times
- Has thanked: 206 times
- Been thanked: 562 times
Re: Zombiverter VCU Charging Cut-Off Guidance
Please provide a CAN log too.
Also what generation of Leaf PDM? What is the battery pack and BMS?
gen 2 PDM, l connected 24 catl modules (4S1P, 180Ah,nominal voltage 14.8) and leaf BMS. Am going to log CAN later and l send
- Bratitude
- Has thanked: 168 times
- Been thanked: 349 times
If u disconnect the bms, will it keep charging? What size battery was the bms from?
You set "BMS_Mode": 0
Yet you have a Leaf BMS?
What firmware version are you on?
I disconnected the bms. It was a 24kw bms but am planning to buy flying ADC bms
I disconnected the bms . Am using the latest firmware 2.20A
