Hyundai Ioniq Inverter Pinouts
FerrySteve
Post by FerrySteve »
Very much a work in progress but hopefully of use to other members😁
Ioniq Pinouts Main MCU & Layout.pdf
(8.13 MiB) Downloaded 328 times
Ioniq Pinouts IGBT gate Board.pdf
(8.63 MiB) Downloaded 298 times
Ioniq Pinouts Powertrai Periferals.pdf
(5.97 MiB) Downloaded 264 times
projectgus
Has thanked: 19 times
Been thanked: 14 times
Re: Hyundai Ioniq Inverter Pinouts
Post by projectgus »
Hi Steve,
Thanks for posting these! FWIW, you can sign up for a Hyundai Service portal account here https://service.hyundai-motor.com/ and if you pay them 15EUR for 24 hours then you can access a lot of service info including harness diagrams and module pinouts (under the "ETM" section). The site doesn't have anything inside the EPCU, it's a black box for external repairers, so no IGBT gate driver pinout. But they do have the main EPCU pinout of the big connector.
Did you make any progress with the Ioniq inverter? I just bought a wrecked Kona that looks like it has a very similar or identical EPCU stack in it. Currently working out what my plan is for that...
Been thanked: 87 times
Thank you for this and for sharing your findings.
