Chevy Volt Gen 2 charger 24281923
TonyV
Re: Chevy Volt Gen 2 charger 24281923
Post by TonyV »
I've looked high and low but I cant find anywhere the pin layout for the GEN 2 battery charger control plug.
Can someone tell me where Pin 1 is? Or better yet a link to a pinout somewhere would be awesome.
I checked amber's blog and he describes the pins but I really could use the pin layout.
Ok, i am away from PC now and cant do much. But observe in my blog how i used all black wires with numbers and single green/yellow wire. Well that is P2 GND (black wire in your photo) wire. P1 is not populated and then you can count wires from there. You only really need 4 wires P2, P4, P9 and P11.
I think you can also download molex connector datasheet to see pinout distribution.
I will draw a schematic when i am home...
TonyV
Post by TonyV »
Can the Gen2 Charger be controlled by CanBus?
TonyV wrote: Wed Jul 28, 2021 7:40 am Can the Gen2 Charger be controlled by CanBus?
No, gen2 charger needs PWM duty command to start and it reports with PWM duty on dc voltage and power.
zippy500
Post by zippy500 »
Is this the correct unit-its labelled as 3.3kw
https://www.ebay.co.uk/itm/273706742983 ... 1438.l2649
zippy500 wrote: Wed Jul 28, 2021 7:16 pm Is this the correct unit-its labelled as 3.3kw
Yes it is Volt gen2 charger. The gen1 was 3.3kW but it also had 250W 12V charger inside. So technicaly it was close to 3.6kW all in all.
I think 3.6kWh applies if you consider 9.3A at 380Vdc which i got from it on last try!
DANG! I tried to charge a 104S battery and Gen2 charger just wont work over 400Vdc.
Whereas when i tried with 96S battery it started to charge immediately.
That is a shame!
EV_Builder
Post by EV_Builder »
Anyone has spare connectors for this charger?
Trying my best to find them but not on stock or per 50 etc
EV_Builder wrote: Mon Oct 11, 2021 9:46 am Anyone has spare connectors for this charger?
At the time i was ordering my set they were relatively good priced. Now they are unobtanium. I sold my charger but i was preparing to remove connectors and make alternative flanges with grommets for cables. Maybe model for 3d primter similar to outlander motor?
I think it would be easier to make new connection and seal it with sika or similar sealant.
thetdiguy
Post by thetdiguy »
Im interested in one of these will it work for 108s Lifepo4 pack 404vdc max ?? Seems like mouser has no stock on hv connectors
No they dont work above 400Vdc.
thetdiguy
Post by thetdiguy »
So what is maximum actual voltage ?
thetdiguy wrote: Sat Nov 20, 2021 5:38 pm So what is maximum actual voltage ?
I tried 378, 388V and 392V.
I also tried 410V and it would only start at 9A and shutdown after 1s.
thetdiguy
Post by thetdiguy »
So you confirmed up to 392 ?
thetdiguy wrote: Sat Nov 20, 2021 9:33 pm So you confirmed up to 392 ?
Well yes i got my battery up to 392 using Volt gen2 charger.
