can some any one provide some what the internal diameter of the coolant ports on the pcs are?
im working on some adapters and dont have a pcs near me
PCS coolant port measurements [SOLVED]
- Bratitude
- Has thanked: 60 times
- Been thanked: 176 times
- Has thanked: 285 times
- Been thanked: 65 times
Re: PCS coolant port measurements
I have one on the bench at home so can grab some dims later this evening
- Has thanked: 96 times
- Been thanked: 96 times
Re: PCS coolant port measurements [SOLVED]
I measured one I have in storage with a digital caliper.
Inside diameter is 22mm, but flares near the opening to 23.7mm
Outside diameter is 26.1mm, appears to be fairly straight, except for the bead, which is 30.4mm outside diameter.
