Tesla SDU - Unable to get any regen at all  [SOLVED]
cloudy
Been thanked: 7 times
Post by cloudy »
Pulling my hair out, so posting here as a last resort. Otherwise fine Tesla SDU running on openinverter - however I cannot no matter what I try and do, get any regen at all (potnom never drops below zero)
Params attached, but I've tried many variations and trying to have pot2 both set to zero and 4095. My expectation is there should be some regen ramped in when off throttle. I'm really hoping I've missed something incredibly stupid. Can anyone suggest? Is it possible I need a pot2 value above the value of ~23 I have now - even when setting pot2 max to zero?
Running 5.14 - params attached
Thankyou!
params (1).json
(1.44 KiB) Downloaded 179 times
Has thanked: 384 times
Been thanked: 1589 times
Re: Tesla SDU - Unable to get any regen at all
Looks ok. Is udc measuring correctly?
cloudy
Post by cloudy »
Yes, reading about 400V - I've even reapplied damian's default params and tried to add some regen to no avail. Perhaps I have a corrupt config memory? Is it worth using the default revert button?
remy_martian
Post by remy_martian »
Is there a flag or other boolean / signal that says the battery is fully charged?
Friends don't let software friends do hardware design
If the parameter memory is corrupt it will load (useless) defaults anyway as a CRC is stored along with the parameters.
I'm assuming your throttle is also calibrated correctly?
cloudy
Post by cloudy »
Yes, throttle within range. I've also added a brake digital input and wired up pot2. Even with pot2 calibrated and set high - potnom never drops below zero. Pulling the digital brake input high shows activated, and inhibits throttle, but again no regen and no negative potnom at rest or whilst motor spinning. Error memory showing no errors.
What parameters out of range could cause regen to be inhibited? udcmax, idcmin, throtmin, bmslimlow? Possible to have a sign wrong? idcmin should be entered as negative value right?
   throtSpnt = GetUserThrottleCommand();
   bool determineDirection = GetCruiseCreepCommand(finalSpnt, throtSpnt);
   finalSpnt = Throttle::RampThrottle(finalSpnt);
   if (hwRev != HW_TESLA)
      Throttle::BmsLimitCommand(finalSpnt, Param::GetBool(Param::din_bms));
   Throttle::UdcLimitCommand(finalSpnt, Param::GetFloat(Param::udc));
   Throttle::IdcLimitCommand(finalSpnt, Param::GetFloat(Param::idc));
   Throttle::FrequencyLimitCommand(finalSpnt, Param::GetFloat(Param::fstat));
   if (Throttle::TemperatureDerate(Param::GetFloat(Param::tmphs), Param::GetFloat(Param::tmphsmax), finalSpnt))
      DigIo::err_out.Set();
      ErrorMessage::Post(ERR_TMPHSMAX);
   if (Throttle::TemperatureDerate(Param::GetFloat(Param::tmpm), Param::GetFloat(Param::tmpmmax), finalSpnt))
      ErrorMessage::Post(ERR_TMPMMAX);
Does that help? It's not the BMS input it is masked out on Tesla hardware. It's none of the temp deraters because they would limit acceleration as well and trigger an error message. idc/udc you have configured correctly. Maybe try setting idlemode to off?
Re: Tesla SDU - Unable to get any regen at all  [SOLVED]
Oh yeah, just checked again. You have speedkp=0 . That means the idle speed controller will override any negative throttle. Not greatest usability I admit. Set idlemode off and speedkp=0.25
cloudy
Post by cloudy »
That fixed it! Many thanks 8-) 8-) 8-)
modellfan
Has thanked: 17 times
Been thanked: 22 times
Post by modellfan »
 bool Throttle::HoldPosition(int distance, float& finalSpnt)
   //do not act when rolling forward and exit hill hold mode
   if (distance > 10000) return false;
   finalSpnt = (holdkp * distance) / 1000;
   finalSpnt = MIN(idleThrotLim, finalSpnt);
   finalSpnt = MAX(0, finalSpnt);
   return true;
Ran into the same thing . Also hillhold kills regen ? And hilhold seems like not working in reverse mode ?
Goes on my bugfix todo
Proton
Has thanked: 191 times
Been thanked: 49 times
Post by Proton »
cloudy wrote: Mon May 30, 2022 10:50 am That fixed it! Many thanks 8-) 8-) 8-)
can you post your current parameters? I have the same problem. No regen.
