Toyota Prius Gen3 Board
Prius Inverter
Control Board
Development History
Vendors
Support
Inverter Model Numbers
| G9200-47141 | Auris 2012, RHD | ||||||
| G9200-47190 | Auris | F1759-52010 04 | ? | Forum Thread openinverter.com | |||
| G9200-52010 | Yaris | F1759-52010 04 | F1789-52010 | 154x143mm | https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828 | ||
| G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com |
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
Main Firmware
For Windows
Atmega328p Firmware
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
IDC Connector
If you are not using the AMPSeal daughterboard, you can connect directly to the 34 pin IDC connector on the EVBMW board. Connections are as follows:
| 23 | MG2_STATOR_T1 | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 24 | MG2_STATOR_T2 | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 25 | MAIN_CON | 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 26 | PRECHG_RLY | 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 27 | AC_CON | 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 28 | HV_CON | ? |
| 29 | AC_PRECH | 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 31 | EVSE_PROX | |
| 32 | CONTROL_PILOT | |
Ampseal Socket & Plug
| 22 | MOTOR TEMP SENSOR A | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 23 | MOTOR TEMP SENSOR B | 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V. |
| 24 | MAIN HV CONTACTOR | 5V output to switch main HV contactor. Note that you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 25 | HV PRECHARGE RELAY | 5V output to switch the pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 26 | CHARGER AC INPUT RELAY | 5V output to switch the main charger AC input relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 28 | CHARGER AC PRECHARGE RELAY | 5V output to switch the charger AC input pre-charge relay. Note you cannot switch these 12V devices directly from this output. You will need either a transistor or smaller relay arrangement to provide the appropriate voltage/current. |
| 34 | NOT USED | |
| 35 | NOT USED |
Connecting Resolver
Bill of Materials (Github)
