Mitsubishi Outlander Rear Inverter
| Property | Value | Source |
| Device | Inverter | |
| OEM | Mitsubishi | |
| Type | 3 phase Motor inverter/controller & HV DC Junction Box | |
| Part Number(s) | 9410a163 | |
| Mitsubishi Module Name | REMCU | http://mmc-manuals.ru/manuals/outlander_iii/online/Service_Manual_2013/img/90/HKAF0E02CC00ENG.pdf |
| Suppliers | Ebay | |
| Voltage | 300V DC Nominal supply voltage
(336V Max according to max battery voltage) |
Based on Mitsubishi Outlander Pack voltage and data from here for maximum voltage: |
| Interfaces | 1x Resolver/Motor Temperature sensor interface - Hirose GT18WB-14DP-HU - 14 way proprietary connector
1x 12V Power/CAN Bus Interface - Hirose GT18WB-14P-HU - 14 way proprietary connector 1x DC Bus Input - M10 Bolts with gland plate 1x 30A Fused DC Bus Junction Output - M10 Bolts with gland plate 1x 3 Phase motor output - M10 Bolts with gland plate |
https://www.hirose.com/product/document?clcode=&productname=&series=GT18W&documenttype=Catalog&lang=en&documentid=D49386_en |
| Mechanical Mounting | 3x Lugs around lower face, M10 bolts multiple locations | Author experience |
| Resolver | Presumably matched to resolver on Outlander Rear Motor
SIN COS - P/N C69600/TS2239N484E102 Believed to be similar to Nissan Leaf resolver |
| Power | Unknown if continuous duty is based on inverter or motor thermal capability
70kW Peak 25kW Continuous |
| Weight | 9kg | Author experience |
| Features | Integral 3-way DC fused Junction box (1 input, 2 fused outputs)
Water cooled 2x Coil temperature sensors |
| Wiring Diagram | http://mmc-manuals.ru/manuals/outlander_iii/online/Service_Manual_2013/img/90/HKAF0E02CC00ENG.pdf |
