Tesla Model S/X Small Drive Unit ("SDU")
Revision as of 15:23, 18 April 2026 by MoonUnit (talk | contribs) (Added a link to RSDU coolant port 3D files i created.)
Tesla uses the Small Drive Unit (SDU) in dual-motor versions of the Model S/X. The Front SDU (FDU) is found in performance and non-performance dual-motor models, while the Rear SDU (RDSU) is only found in non-performance dual motor models.
Wiring
Small Drive Unit ("SDU") Data Connector
Low Voltage Data Connector
Small Front Drive Unit ("SDU") Data Schematic
Housing
Molex MX150 33472-2002 (key “B”)
Pins:
22 AWG:      Molex 33012-2003
18-20 AWG: Molex 33012-2002
14-16 AWG: Molex 33012-2001
High Voltage Power Connectors
Although the connectors are known (Rosenberger HPK series), they are not available through conventional vendors.
Internal connectors
20-pole Molex: 75757-5101
2-pole temp sensor: S02BA-AIT2-1AK
6-pole encoder: S06B-AIT2-1AK
24-pole inverter: CES-112-02-T-D
Drop-in control board
Tesla SDU drop-in board
Dual Pot mode, connect pot 2 to pin 10, BRAKE TRANSDUCER SIGNAL.
Note: see this thread regarding throttle pedal safety https://openinverter.org/forum/viewtopic.php?p=75841 this applies to the SDU boards.
Resources
Wiring
Wiring connections
Wiring with Zombieverter
MX150 male header receptacle STL on Thingiverse
Buying
Purchase in openinverter shop
Tuning
SDU Tuning Optimization Forum Thread
Original Parameters from Johannes
Parameters tuned by catphish
Setup FAQ
Application Info
It is essential that the tripmode parameter is set to 1 "DcSwOn". Also do not use a low value fuse while testing. On over current trips some energy is still stored in the motor and it has nowhere to go if the contactor/fuse opens leading to immediate destruction of your inverter.
Cooling
Small Front Drive Unit (FDU)
Tesla FDU cooling
Small Rear Drive Unit (SRDU)
Tesla SRDU cooling
Various step files for printing your own coolant port here:
https://www.printables.com/model/1693168-tesla-model-s-rear-sdu-coolant-port
There are three files - a dxf which is the basic outline if you want to cut your own plate and thread it yourself. There is a BSPT version, which has a 3/8in thread for a hosetail, or a complete version with outlet attached. You will need to make your own choice regarding material to use.
