Tesla Model S GEN1 Charger
The Tesla Gen1 on-board AC charger (OBC) was a single phase 10kW AC charger that was fitted originally and primarily in the Tesla Model S, from Jun2012 through late2013*, when it was replaced with Gen2. Gen1 models are easy to identify, having the word "TESLA" stamped on the top metalwork and having no black anti-tamper tape; the Gen2 charger lacks the Tesla identifier stamped on the metalwork, and has anti-tamper tape over the seams.
One (or optionally two, in a Master/Slave configuration) Gen1 chargers are installed beneath the rear seats in the Model S for AC charging. The Single/Master OBC is on the right side of center. If two OBCs are fitted, the Second/Slave is fitted to the left of center under the rear seat; both are identical hardware, though the firmware differs.
The Gen1 chargers are considered to be more trouble-prone than the later units, and are not as popular for use in EV conversions or ground-up builds, partly because they do not support 3-phase AC input. However, they are used in many OEM installations that continue to need servicing. Examples of OEM installs include Telsa (all 2012-Sep2013 Model S), Toyota (all 2012-14 RAV4 EV[1]), and Mercedes-Benz (initially "Electric Drive", later "B250e"[2], 2014-15?**). As far as is known, these are identical from a hardware perspective[3], but the firmware differs and is not interchangeable between installations.
A version of this unit was used in early Tesla Supercharger DCFC stations, with several ganged in parallel.
* The Gen2 OBCs were apparently phased in gradually. There are reports of Dec2013 with Gen1 OBCs[4], and Oct2013 with Gen2 OBCs[5][6].
** A 2016 B250e was reported to have a Gen2 OBC installed.
Charger Connectors
There are six discrete connectors on the Gen1 OBC.
- AC (Input)
- DC (Output)
- the HVIL Loop connector
For Logic Connector X042 (X043, when referred to when provisioned in "Slave" duty, D4 in the Toyota RAV4 EV), the mating connector needed to plug into the charger is Molex 19418-0026[7] for 18-22 AWG (19418-0027 for 14-16 AWG) which is in the MX150L series. This connector features CPA[8] (Connector Position Assurance), a dual-locking feature. For bench-testing, etc., the non-CPA connector is Molex 19418-0038[9] for 18-22 AWG (19418-0037 for 14-16 AWG); this connector requires one less operation to disengage, but is less suitable for automotive use or environments where heavy vibration is present.
Wire size * |
Telsa
Wire Color * |
| 2 ** | Charge Port: nozzle lock | "InsertEN out" | 20 AWG (0.5mm²) | YL |
| 6 ** | Fast Charge CAN | "FC_CAN". Possibly SWCAN. Connects only to BMS "FC_CAN+" | 20 AWG (0.5mm²) | RD-WH |
| 8 | EVSE-Prox (PP) OUT | PP signal from EVSE to Drive Unit. Marked "Prox out" on Tesla's documentation, this was thought to be a "inhibit drive" signal, but testing has been inconclusive/negative for that function so far. | 22 AWG (0.35mm²) | OR-PU |
| 11 | EVSE-Prox (PP) IN | PP signal from EVSE to OBC | 20 AWG (0.5mm²) | OR |
| 12 ** | "BMS_12V_in" | "Cont_PWR (out)" (Contactor power?) from BMS (BMS enables DCFC contactors?) | 18 AWG (0.75mm²) | RD-GY |
** = Not used on RAV4 EV.
AC Input Connector
DC Output Connector
HVIL Connector (J5)
- Tesla: The loopback harness, Tesla 1101371-00-A, is included/stored inside all Tesla Model S Gen1 Rear HVJB in an internal "parking" socket, when only a single OBC is provisioned.
Common Issues
Grounding
Fuses
Important Considerations
Output Voltage Range
| HEED DAMIEN'S WARNING:[21]
(regarding the Gen2 OBC, which may or may not apply to the Gen1) |
CAN
WIP
- Weight: 42 lbs (19 kg)
Tesla Part Numbers (TPN):
- 6009278-00-x
- 6009354-00-x
Toyota Part Numbers:
- G9090-0R010 (discontinued)
- G9090-0R011
MB Part Number(s):
- TBD
